  • July 19, 2025, 06:15:40 PM
Author Topic: How do you set your gun?  (Read 2957 times)
Online Paul Taylor
« on: April 14, 2013, 07:55:32 AM »
Ok I might get to spray again today.
Is there a better way to set your gun?
I put paint in and spray a lot of liquid gold on a test board before I think I have it set right only to start spraying the parts and find it is spitting  spots instead of a mist.
Offline RC Storick
Re: How do you set your gun?
« Reply #1 on: April 14, 2013, 08:53:27 AM »
More pressure.
« Reply #2 on: April 14, 2013, 09:15:13 AM »
Or you need to clean your gun.
When was the last time you had it completely disassembled for cleaning?  Did you buy it new or used?
Is it always spraying droplets? (If so, Robert's guess is probably right, or you have a clogged passage).  Is it an old-style or an LPHV gun?  (If it's LPHV, I don't know much about it).  Is it going "phut phut", sometimes spraying droplets and sometimes spraying a nice fine mist?
Most important -- what pressure are you running?  I run 30-40 pounds to my touch-up gun, which is less than I wanted to but all that my half-broken-from-the-store Horror Fright "regulator" can manage.
Online Paul Taylor
« Reply #3 on: April 14, 2013, 09:26:46 AM »
Both my guns are new and I do a break down after each use.
More pressure.
Thanks guys
« Reply #4 on: April 14, 2013, 11:57:49 AM »
Or the material is too thick. Generally, if the material is coming out in splats, it's either not enough pressure or the material needs to be thinned more. Or both.
Online Paul Taylor
« Reply #5 on: April 14, 2013, 01:04:19 PM »
Thanks Randy.
It's about a 60/40 mix.
« Reply #6 on: April 15, 2013, 04:39:06 AM »
It could be one of the reasons listed by Sparky or Randy. Another thing to think about is filtering the paint. I use TWO paint filters (the ones you get at the auto paint store) when filling my gun.
Derek
« Reply #7 on: April 16, 2013, 01:56:38 PM »
Some colors of dope need less or more thinner than other colors. Green and most blue or darker colors do not need so much thinner. They are also lighter than lighter colors. White and cream or yellow take more thinner. On clear I generally thin with at least 60% thinner and sometimes more. This is what works for me anyway in my gun or air brush. I do use an old style gun that is around 35 years old, and like about 40 to 60 psi at the compressor. If you use a 20' air hose you will have a lot less pressure at the gun.
Offline DanielGelinas
« Reply #8 on: April 16, 2013, 05:48:53 PM »
Jim, are you saying 20 foot of hose is too long? what is the correct length to get the correct pressure?
-Dan H^^
Eric Viglione
« Reply #9 on: April 16, 2013, 08:57:17 PM »
A pressure regulator at the gun air inlet seems the best solution I've used so far. Set the compressor a little higher than needed, then fine tune at gun.
EricV
Offline Doug Moon
« Reply #10 on: April 17, 2013, 08:56:13 AM »
I use a top feed HVLP gun from Harbor Freight.  I have two, one for clear and one for color.  They are older and work well.  I ran into this very problem the first time I used them.
Solution, more pressure.  I set the line pressure at about 90 psi.  I have a small in-line regulator at the inlet of the gun.  I set that to the desired 7-10 psi range depending on the material I am spraying.  I have had no spitting issues since, when the gun is clean and in good working order, fingers are crossed and knocking on all kinds of wood now.  Also on my model there is a small pressure adjustment screw on the bottom of the gun but there is no gauge so its hard to use.  With the inlet gauge I can see the pressure settings and I leave the one on the gun base wide open.
An inline gauge at the base of the gune is a must.  It just makes things that much easier.  Plus they are pretty cheap. With the line pressure way up you will never get pressure buildup or drop off in the gun no matter what the compressor is doing.  I use a 20' hose as well.
Doug Moon
AMA 496454
Dougmoon12@yahoo.com
Offline RC Storick
« Reply #11 on: April 17, 2013, 09:40:32 AM »
Randy mentioned too thick. This might be the problem but unless its coming out like spiderweb I don't think so. Sometime try straight dope and as much pressure it takes to get it to spry and see the effect. Its what they use to do in the 60TYS. Kinda Cool!
Online Paul Taylor
« Reply #12 on: April 17, 2013, 07:12:33 PM »
Well if the rain will ever go away i might get to spray some clear.
Offline Fred DiMaria
« Reply #13 on: September 01, 2013, 07:45:44 AM »
What is a suggestion for PSI at the gun to spray clear dope? The gun is a HVLP harbor freight unit. I used about 35 psi at the gun.  I have not worked with dope much, but I am attempting to finish a ringmaster with it. I sprayed a coat of clear on last weekend, mixed about 50% clear and 50% thinner. I found it dried very quickly and went on as almost as a haze. I could not get easily get a wet coat look.  This is going to be a knock around model, I am not that concerned with buffing, so I was hoping to get enough gloss with a clear coat, but I am not happy with the resulting gloss.  Thank you
« Reply #14 on: September 01, 2013, 08:34:04 AM »
Not an expert on this like some, but I think the dope gloss comes after it cures and is rubbed out.   The automotive clears seem to cure with a gloss after the second coat.   I usually hit with a light coat and then with a heavier coat on second application.
« Reply #15 on: September 01, 2013, 09:34:08 AM »
I had wet sanded last weeks clear with 1500 then 2000, and tried to apply a nice finish clear coat and my results are terrible, uneven, not glossy and overall hazy finish. I attached a few pics. I used brokack clear, with some sig retarder and brodak thinner.
« Reply #16 on: September 01, 2013, 01:39:46 PM »
Hi Fred,
From your pictures it appears you have a case of blushing.  It occurs, as you probably know, from high humidity.  We have the problem here most of the year.
BIG Bear
RNMM/AMM
« Reply #17 on: September 02, 2013, 09:22:31 AM »
Yep as Big Bear says that is blushing.   I have a Thirteen I built for Old Time and was covered in poly-ester clothe.  The clear kept blushing on me and I was brushing it.   Just before VSC I got out side the shop,  Temps in the low 60's and very low humidity.  Brushed on one more coat of clear.  By the time I got every thing put away I looked at the plane and it was shiny with no cloudiness.
« Reply #18 on: September 02, 2013, 09:41:14 AM »
I did some research on line which says you can eliminate blushing by spraying 100% thinner over the blush on a low humidity day. Has anyone tried that?
Also, can you simply wet sand and polish the blushed dope to a glossy finish?
Its still soupy out here in CT, so I have to wait....
Offline Allan Perret
  • Proverbs
« Reply #19 on: September 06, 2013, 07:44:51 AM »
Yes I have done that and it works.  But you have to be careful to just mist it on with the gun twice the normal distance from the surface.  You don't want to get the surface "wet" with just thinner.   Yes also to 2nd question.
Allan Perret
AMA 302406
Slidell, Louisiana
Offline sleepy gomez
« Reply #20 on: September 08, 2013, 04:18:11 PM »
Paul, if you have a non-HVLP gun then put some oil around the packing nut on the shaft.  These packings dry out out after a lacquer or other thinner type wash.  Air is then sucked in causing the eratic flow.
« Reply #21 on: September 09, 2013, 10:29:35 AM »
I now use a top-feed spray gun.  With gravity on your side, it takes less thinner in the dope.  So result is fewer coats to do the job.  30 psi is about max. - any more, and the paint has so much velocity that it "bounces" off and fills my shop with clouds of paint dust!
« Reply #22 on: September 09, 2013, 11:45:29 AM »
I was surprised at how my pressure I had to use with my nominally HVLP gun. I dial up the compressor to max (about 120lbs) and use the regulator at the gun to dial in the amount of pressure needed. With the Finex gun I use from color, it ends up being between 30-40lbs though the gun says no more than 10lbs. But it works well there (and yes, I know you check the pressure with the trigger depressed). I set it at around 35lbs and it drops to about 15lbs when used. This seems to work pretty well. I use more than that with the SATA clear gun. But I'm usually shooting catalyzed polyurethane and that is a somewhat different deal.
