  • July 13, 2025, 03:05:29 AM
Author Topic: How can I remove a decal from a painted surface.  (Read 2057 times)
Offline Perry Rose
« on: March 23, 2018, 01:40:32 PM »
I have a Bearcat with stars and bars, from Major decals, on the fuselage sides and I want to remove them without damaging the paint. What do I do?
Re: How can I remove a decal from a painted surface.
« Reply #1 on: March 23, 2018, 02:10:09 PM »
Perry,
I thought they were vinyl so don't use heat.
Major decals makes a decent product.
I would call them, they will talk to you.
Just to be sure.
C
Offline Mike Haverly
« Reply #2 on: March 23, 2018, 02:15:00 PM »
Water slide decals come off easily with 1000 grit paper.  Use wet and a lot of finesse. They will peel easily after softened.  Vinyl stickers, use a little heat.  I'm pretty sure Major has made them both styles from time to time.
Offline bill bischoff
« Reply #3 on: March 23, 2018, 02:24:56 PM »
Sometimes you can remove water slide decals by rubbing tape over them and lifting briskly. Don't stick the tape to anything other than the decal itself! n1
« Reply #4 on: March 23, 2018, 03:29:40 PM »
That's correct, just make sure they haven't been sealed with a clear coat.  You just might remove more than just the decal.  I have some that are buried under many coats of clear and need to be sanded first.  After sanding through the clear they will come off easily.
« Reply #5 on: March 23, 2018, 04:35:03 PM »
Do I remember vinegar being used to remove decals?
Could try just a corner.
« Reply #6 on: March 24, 2018, 12:30:15 AM »
Vinegar kills lawn weeds.
Offline Perry Rose
« Reply #7 on: March 24, 2018, 06:33:51 AM »
I got a good look at the pressure sensitive decals and they didn't have that clear border that Major Decals has. These could be from the Brodak kit. So using all the advise given here I peeled up a corner, warmed the decal a bit and gently pulled them off without damage or glue residue . Now I have to remove the trim kote numbers and markings. They leave glue if heated so this could take a while.
« Reply #8 on: March 24, 2018, 09:49:00 AM »
Perry, if you leave a glue residue, use lighter fluid to remove it.  It won't do anything to your paint and will take that residue off quite nicely.  Be generous with the fluid and you might need to do a couple of applications, but patience will win.
