  • June 17, 2025, 05:14:17 AM
Author Topic: Butyrate dope is fuelproof, but to what extent?  (Read 6619 times)
Offline Paul_BB
« on: November 06, 2016, 01:17:22 AM »
Hi,
Living in Europe I use nitro dope rather than butyrate dope to finish my models. I spray on a last thin coat of clear epoxy because as everybody knows nitro dope is not fuelproof.
I have been watching Windy Urtnowsky's fantastic videos for a while and would like to try butyrate dope. But my question is: to what extent is butyrate dope fuelproof (to what nitro content)?
Offline kenneth cook
Re: Butyrate dope is fuelproof, but to what extent?
« Reply #1 on: November 06, 2016, 09:12:30 AM »
            Paul, my experience has made me come to the conclusion that Sig Lite Coat clear is best in clarity and being fuel proof. I'm not even certain if that's available to you in Europe. I have had very good success putting it over Brodak dope. You must build up a few coats of clear especially in the nose area due to handling, fuel spillage etc. I also found that wiping it off immediately improves it's durability. That being said, I use car wax on the nose area and tank area on profiles. The bottom line is to just be careful. Some of the current fuels I use have dyes in them such as red which can stain and therefore I'm very careful in cleaning up mild spillage. Some of the guys have been spraying two part auto clear on the nose area only. This typically gives that area a very shiny appearance but makes it 100% fuel proof. If the clear coats haven't been built up, I have seen 10% nitro fuel make the paint come off on the towel when wiping the model clean.
« Reply #2 on: November 06, 2016, 10:41:29 AM »
The bottom line is raw fuel will eat into a dope finish fairly quickly. But if you have enough clear on it, especially around the nose area, it's pretty durable. You just need to be a bit careful with filling the tank and priming the engine with raw fuel. Exhausted fuel doesn't seem to hurt it. An all dope finish lasts for years and is much easier to repair than a dope finish with epoxy or automotive clear coat.
Offline Paul_BB
« Reply #3 on: November 07, 2016, 08:58:35 AM »
Thanks for your answers guys.  :)!
Reading your posts it strikes me that what you call clear is not butyrate.
I ordered some butyrate dope, thinner and retarder from Brodak. I also found on their site what they call Crystal Clear (for the final coat.)
But before reading your posts I thought that Brodak Crystal Clear was also made of butyrate. If not, what is Brodak clear made of?
Offline Jim Svitko
« Reply #4 on: November 08, 2016, 07:44:48 AM »
Brodak dope, from what I heard, is made by Randolph.  Both nitrate and butyrate can be bought under the Brodak or Randolph hame.  A few months ago I heard that Certified bought Randolph but I have not been able to confirm that.
The Brodak formulation might be a bit different from the Randolph/Certified product but they are compatible.  I have used Randolph butyrate thinner with Brodak dope, and vice versa, with no problems.  I have applied one over the other with no problems.  This goes for clear as well as colors.  Much cheaper to buy Randolph thinner and use it with Brodak dope.
The Brodak Crystal Clear does not appear to have much, if any, fuel resistance.  I have planes with dull blemishes on them where raw fuel made contact.  Although I like the fact that it is "crystal clear" and might not yellow as much over time, its fuel resistance is minimal.  From the quick and dirty experiments I did, the Randolph non-tautening clear appears to have more fuel resistance than the Brodak Crystal Clear.  Not that it is fuel proof, just a bit more resistant than the Brodak clear.
Offline Paul_BB
« Reply #5 on: November 08, 2016, 09:16:06 AM »
Thanks for your inputs. I think I will stick to fuelproofing with a fine coat of epoxy clear.
Offline Dane Martin
  • heli pilot BHOR
« Reply #6 on: November 09, 2016, 06:47:01 PM »
Ok so I want to make a vintage combat plane, and just clear the wood, and SLC or Fascal on the wings. Can I just use butyrate dope after the wood prep? Or does it need something over the butyrate? I've seen many many "clear" combat planes. What's the trick?
« Reply #7 on: November 10, 2016, 02:57:07 AM »
            Yes, you can clear butyrate over the wood. The trick though is not to get fuel on it. Build up many coats  as mentioned and wax it to prevent damage. If your bumping up the nitro, more caution is needed. This can take 6-8 coats.  If you want the finish impervious to fuel, spray 2 part auto clear on the nose. I use nitrate for most of my base coats  due to it's compatibility with almost any finish.
« Reply #8 on: November 10, 2016, 12:11:20 PM »
Back in the day, I used colored silk for my combat planes.   Glass cloth and epoxy around the nose and dope on the rest.   I used clear dope until it kind of a sheen to it.   Never a problem with the fuel available back then.  Of course 10% nitro is all I used.
Of course there was always a pin hole or several that let fuel in.
Offline Dane Martin
  • heli pilot BHOR
« Reply #9 on: November 10, 2016, 03:39:13 PM »
Thanks guys
Tags: butyrate dope fuelproof
