  • June 27, 2025, 06:40:56 AM
Author Topic: Here's how I'm doing the Akromaster  (Read 1499 times)
Offline Jim Pollock
« on: December 01, 2009, 10:28:11 PM »
My Akromaster is covered and has 5 coats of Sig Clear on it.  I'm going to wet sand the clear over wood but not tissue and then do one more coat of clear tinted with light gray I will sand that down as far as I can then do two light coats of Spray Can (Dupli-Color) Acrylic Lacquer white.  After that, the trim colors will be applied with an air brush and will consist of Sig Butyrate dope in colors of Black, Fokker Red and Miami Blue.  Clear coat will be a two part urethane that Tom has sitting around his shop.  I don't know how it will come out but I think all the parts are compatible...
Jim Pollock    n~
Re: Here's how I'm doing the Akromaster
« Reply #1 on: December 02, 2009, 07:18:08 PM »
You're going to spray dope colors over spray can paint? I wouldn't. I've seen dope eat just about anything it's sprayed/brushed over. Have you done this before and gotten away with it?
« Reply #2 on: December 03, 2009, 01:44:40 PM »
Clint's right, it's tough to tell. Could work fine. Remember, just because it's all lacquer doesn't make it compatible. The thinnners used can cause some interesting effects. Crinkle finish anyone?
Offline Jim Pollock
« Reply #3 on: December 03, 2009, 07:55:24 PM »
Ummmm,
It does sound compatible, maybe i'll test it on another surface first!  I really don't see how butyrate is going to be incompatible with Acrylic Laquer - but anything can happen these days.......
Jim
« Reply #4 on: December 03, 2009, 10:44:10 PM »
Ummmm,
Jim
Post a report on results, Jim. I'm interested to see the outcome.
« Reply #5 on: December 04, 2009, 08:56:55 AM »
>>I really don't see how butyrate is going to be incompatible with Acrylic Laquer - but anything can happen these days.....<<
Ask Mark Scarborough about compatible finishes. Even when you do everything right, you can get something weird happen because of humidity, or thinner temps or other factors like the cleaning product you used to clear the surface prior to the next coat. Phil Granderson recommends Windex (largely, I imagine, because it's fairly inert with paint). Alcohol can get you in trouble as can some surface cleaning agents. Lately, I've been using straight Naphtha. So far, no problems.
