  • July 30, 2025, 07:58:37 AM
Author Topic: Finish on Skyray  (Read 19173 times)
Offline David_Ruff
  • David Ruff
  • Retired Army
Finish on Skyray
« on: February 27, 2024, 01:09:46 AM »
Just wanted to let you know how I finished the wood/fuselage on my Skyray 35.
Three coats of wood brushing lacquer, light sanding after each coat.
One coat of black Rustoleum enamel.
That's it.
I will let you know how it stands up to fuel.
Just glad to be here
Re: Finish on Skyray
« Reply #1 on: February 27, 2024, 07:17:34 AM »
Dave,
The trick with Rustoleum is to let it cure out at least two weeks before fuel exposure. This seems to be the time it takes to develop fuel resistance.
Best,    DennisT
Offline Mike Morrow
« Reply #2 on: February 27, 2024, 01:18:24 PM »
Hi David, how long after the last coat of lacquer did you wait until you sprayed the Rustoleum?
Sent from my SM-A146U using Tapatalk
Offline David_Ruff
  • David Ruff
  • Retired Army
« Reply #3 on: February 27, 2024, 06:37:10 PM »
I brushed the Rustoleum three days after lacquer.
Offline David_Ruff
  • David Ruff
  • Retired Army
« Reply #4 on: February 28, 2024, 01:49:28 AM »
Nothing fancy.  Just a beginner plane.  Comes in at 28 ounces.
Offline Colin McRae
  • Are we having fun yet??
« Reply #5 on: February 28, 2024, 08:43:06 AM »
Looks great David. Any plan for some canopy color?  :)
I also have a relatively new Skyray with OS 25LA. I did make a few build changes on mine based on some of Brett Buck's suggestions. It flies really well. I am not able as yet to do the full pattern yet, but a buddy of mine did the full pattern with it.
« Reply #6 on: February 28, 2024, 12:54:01 PM »
The canopy stickers from the kit.
Offline MikeyPratt
« Reply #7 on: September 05, 2024, 11:32:12 PM »
Hi Dave,
Nicely built & looking great, I’m sure it will fly very well.  Nice to see it in the stock form even with the single wheel, most of the complaints about the single wheel is they think it’s easer to land with a two wheels, I always liked the single wheel better for a number of reasons, you can whip it on the ground to get it back to your launch point (within reason).  Also, the single wheel makes great landings by holding the nose up until the landing speed slows and just let it settle the last six inches and it lands itself.  On hard a surfaces with the elevator neutral or just a slight amount of down it will roll quit a ways, it won’t take you long to get the hang of that,
Have a blast,
Mike Pratt
Offline Dave Moritz
« Reply #8 on: September 06, 2024, 09:02:26 AM »
Paul: It appears they’re a perfect match.
Dave Mo…
