Hey Will,, as you know,, cleaning the gun is part of the spraying process,, DOH!,, LOL
the real tragedy is when you get urethane cured in a gun and ruining the gun,, I sprayed a car one time,, spot repair,, and as I was putting on the last coat of clear, a customer came in needing an estimate,, It was in the 90s that day, it was about 4 pm,, and they customer had a cool car, and loved to talk. By the time I got his estimate done, It was time to go home,, guess what,, sigh,,
When I clean my guns, I use laquer thinner to flush the gun,, I use a flux brush to scrub it inside and out, I take off the air cap, fluid tip, and needle,, then I flush scrub it with more thinner,, I reassemble the gun, then flush it with Urethane reducer using air pressuer just like I was spraying..
Other than that, What Dandy Randy says,, of course he did fail to mention his special technique using small mammals (bats) to help clean his equipment,, muah ha ha
