  • June 18, 2025, 02:13:25 AM
Author Topic: Filler Coat  (Read 879 times)
Offline James Mills
Filler Coat
« on: May 09, 2011, 05:15:04 PM »
I have 2 coats of filler (clear with Randy's powder) burshed on, plan to sand out in the next day or two.  I haven't put any on the open bays as I've been told to sprat that area.  After I spray the final coat do I sand the open bays at that point?
James
AMA 491167
Offline Allan Perret
  • Proverbs
Re: Filler Coat
« Reply #1 on: May 11, 2011, 06:38:57 AM »
Filler coats on an open bay wing can be brushed or sprayed.  I usually brush on 3~4 coats, and then spray a final coat or two.
Dont try any sanding of open bays untill the weave of covering is completely filled, and you have added several extra coats on just the capstrips.
Actually I find it comes out smoother if you put the extra capstrip coats on first and then the filler coats to the whole wing.
Allan Perret
AMA 302406
Slidell, Louisiana
