  • July 15, 2025, 03:26:18 PM
Author Topic: Film surface undercoat  (Read 918 times)
« on: December 05, 2013, 06:03:49 AM »
Guys,
Getting ready to finish off my rebuilt electric profile with film. I have made some mods to the fuse to add stiffness and allow a more modern % of tail volume. To do the mods I stripped off the original film. I want to get the fuse smooth before applying the new film. I normally apply a coat of Balsarite for film to stick the film firm but it is does not dry hard for sanding. I was wondering if has anyone tried applying a coat of clear dope to the surface to get the fuzz up for final sanding then the Balsarite? Nitra or Butyrate?
Best,     DennisT
Offline Paul Wood
Re: Film surface undercoat
« Reply #1 on: December 05, 2013, 07:58:48 AM »
Dennis,
I don't use dope, but I do use Minnwax lacquer sealer which has similar properties to dope.  It is sandable. I would think you could put Balsarite over it, but I have found that the Minnwax will soften with the heat iron and adhere the covering quite well.  I apply two coats and have used this technique on the past two aircraft I built to apply Polyspan, which has no glue impregnated on the cloth to begin with.  It worked very well.  You also might try white glue.  I have used that method with pretty good results, but I think the lacquer is easier to work with. Hope this helps.
