  • June 16, 2025, 12:01:45 AM
Author Topic: removal of monocote  (Read 903 times)
Offline Dudley Lang
removal of monocote
« on: April 24, 2010, 04:50:50 PM »
I have just finished covering a new plane with monocote.  I have always used silkspan and dope in the past.  I don't like the trim scheme and wondered what is an easy way to remove trim from monocote.  Also, I may want to remove all the monocote and start over with silkspan.  So, if I select to remove everything, what's the easy way to do it.  Thanks Dudley Lang
Offline Leester
Re: removal of monocote
« Reply #1 on: April 25, 2010, 10:07:50 AM »
As far as removing trim, unless it will peal up you're probobly stuck with it. Removing the entire covering is a PITA, heat it up gradually untill you can peal it off then any residue I use accetone to clean the wood with. Good luck with whatever you decide on.
Leester
ama 830538
