  • July 12, 2025, 11:15:38 AM
Author Topic: Filler/dope mix  (Read 1515 times)
Offline James Mills
Filler/dope mix
« on: February 19, 2011, 05:00:12 PM »
I'm to the point on my SV 11 or putting on the filler (Aero 1 mixed in the dope) on the wing.  Do you guys put any of the filler mix over the open bays (polyspan)?
James
AMA 491167
Re: Filler/dope mix
« Reply #1 on: February 20, 2011, 04:39:46 PM »
Only if I have pin holes the clear keeps missing.   H^^
Re: Filler/dope mix
« Reply #2 on: February 20, 2011, 08:30:43 PM »
I usually put about 3-4 coats of unthinned (or just slightly thinned) clear on the airframe (everything) then sand and usually hit it with fillercoat (again, the whole airframe).
Offline James Mills
Re: Filler/dope mix
« Reply #3 on: February 20, 2011, 11:03:22 PM »
Aero 1?  Isn't that the fuel additive?  Do you mean the zinc stearate?  I do use it more and more than talc and a very, very thin coat on the open bays.  But sanding them is a tedious chore for me. I hate it when I cut through the covering at the rib edge (actually cap strip edge) but it happens.  I find using 0000 steel wool makes this part easier and does a fine job.
Thanks Ty, I do mean the zinc sterate (I shouldn't post when I've taken some of this pain medicine n~).
James
AMA 491167
Re: Filler/dope mix
« Reply #4 on: February 21, 2011, 07:07:15 AM »
2 - 3 coats of thinned clear. I also Carbon veil the open bays ontop of silkspan to give strength.
There is nothing wrong wih using the filler over the bay as TY said - be cautious about going through it - we all have done it.
Re: Filler/dope mix
« Reply #5 on: February 26, 2011, 08:23:15 PM »
I'm a dinosaur. I mix up clear and talc (or sometime zinc sterate) with some while and a touch of black to get a gray filler.
Re: Filler/dope mix
« Reply #6 on: February 26, 2011, 10:21:36 PM »
Does anyone else use 0000 steel wool on the open bays?
Offline Neville Legg
Re: Filler/dope mix
« Reply #7 on: February 27, 2011, 01:15:00 AM »
Yes I do, but I still manage to go through the silk HB~> That's why I am considering sheeting all wings from now on!
Cheers
(not) Descartes
