  • July 16, 2025, 06:57:37 PM
Author Topic: Filler for transparent finishes  (Read 4063 times)
Offline Matt Brown
« on: September 17, 2018, 02:52:08 PM »
I’m thinking of doing my first dope finish since the ‘70s. I got some of the heavy plyspan from Sig in orange tint. My intent is to cover the entire plane in this and just use clear dope for a semi-transparent finish. I’ll probably use some black or white dope for trim colors.
I was thinking about the usual spackling being white and showing through. Any other fillers not going to show through? FWIW the plane is a Primary Force.
Thanks, Matt
Re: Filler for transparent finishes
« Reply #1 on: September 17, 2018, 04:30:34 PM »
Zinc stearate. Get it from Randy Smith.
Offline Matt Brown
« Reply #2 on: September 17, 2018, 04:40:39 PM »
Is this a premixed filler? Zinc stearate is normally a white powder.
Matt
Online bill bischoff
« Reply #3 on: September 17, 2018, 04:56:36 PM »
Used to be that there were several tan balsa fillers on the market along with their white counterparts. If you can't find any, you could experiment with white filler and drops of food coloring. Remember, the idea is that it disappears under the orange tissue, so check your results by laying the tissue over your test samples.
« Reply #4 on: September 17, 2018, 10:30:21 PM »
Matt
I’ve mixed it with dope. It gets pretty transparent as I recall.
« Reply #5 on: September 18, 2018, 10:27:43 AM »
I've mixed very fine balsa dust with dope and used that for filler of stuff like dents or gaps. Doesn't really show up under a transparent finish.
« Last Edit: September 19, 2018, 03:01:18 PM by Randy Powell »
Offline Matt Brown
« Reply #6 on: September 18, 2018, 10:55:18 AM »
I've mixed very fine balsa dust with mixed with dope and used that for filler of stuff like dents or gaps. Doesn't really show up under a transparent finish.
I know where there’s a stash of balsa dust ;D
Matt
Offline Steve Berry
« Reply #7 on: September 18, 2018, 11:27:11 AM »
Matt
And now I have this image in my head of shady looking character in a trench coat, calling from an alley...."Pssy. Hey, buddy! I got balsa dust here. 4# density, my man! Only the best."
Online Gerald Arana
« Reply #8 on: September 18, 2018, 01:50:12 PM »
Yes! We used to do that 50+ years ago and it does work well.
Good luck, Jerry
« Reply #9 on: September 18, 2018, 02:15:39 PM »
Matt
I keep a jar of it -- but I mix it with Ambroid, not dope.  I'll have to try it with dope next time.
Offline Paul Wood
« Reply #10 on: September 18, 2018, 04:04:06 PM »
Matt,
I've used this putty from Elmer's for years. I love it.  I've covered it with everything under the sun except dope. But it seems to be compatible with everything, so I can't see why it wouldn't work under dope. I showed both types available to show the one NOT to use. Use the red striped, indoor only. Very easy to sand and color matches balsa perfectly. The outdoor stuff dries too hard for balsa use. You can get it anywhere.
Offline Matt Brown
« Reply #11 on: September 18, 2018, 06:40:04 PM »
Matt,
I searched Lowe’s and Menards local stores but not finding the indoor stuff. They both listed a tub of indoor/outdoor filler in that brand. I’ll try a few other stores tomorrow.
Matt
Offline MikeyPratt
« Reply #12 on: October 01, 2018, 11:43:41 AM »
Hi Matt,
Get in contact with Pete Peterson, he does Awesome clear finishes and I'm sure he could help you out with some of his suggestions.
Later,
Mikey
« Reply #13 on: October 01, 2018, 01:22:38 PM »
I'm surprised at Mr. Wood's comment that the Elmer's Interior/Exterior wood filler "dries too hard for balsa." It has been my preferred filler for years. Better than the "hobby fillers" that used to be available. I recently used up most of a tube and bought some "natural" colored Elmer's--but I did not notice it is the red label interior stuff Paul recommends--so I will get to compare them now. I assumed that they would be the same. If I don't like it, I would definitely go back and get more Interior/Exterior filler.
Here in SoCal, it is my understanding that Elmer's filler is sold exclusively thru Ace Hardware. That may differ in other locations.
If all you have is white water-based filler, I have had some luck with a few drops of coffee as a colorant. I suppose tea would work as well. I wouldn't know where to start with food coloring. The stuff is way potent. I'd probably end up with a plane that looked like a Christmas cookie.
Offline Matt Brown
« Reply #14 on: October 01, 2018, 03:17:26 PM »
I picked up a tube of the Dap interior filler and tried it on a couple spots. Sands great, very lightweight and a pretty close match to balsa. As long as it doesn’t react badly to dope, it’s a winner in my book.
Matt
Offline Mike Haverly
« Reply #15 on: October 01, 2018, 05:10:38 PM »
If you are talking about filler for fillets, Pete uses white micro balloons with epoxy.  For filling the weave in Poy Span he uses zinc stearate in clear dope.  The question is a little ambiguous leading to many different answers.
Offline Matt Brown
« Reply #16 on: October 01, 2018, 06:06:46 PM »
My initial post was about filler for dents, dings and mismatches on the structure. I was concerned about fillers showing through the semi-transparent finish I want to attempt.
Matt
« Reply #17 on: October 01, 2018, 08:31:06 PM »
I consult Pete Peterson often and know him well.  He tries real hard not to put any extra dings while building but still has a few.  He, to my knowledge doesn't use any putt of any kind.  Water and heat will take out dings, pretty deep dents and even swell up broken wood fibers so they can be repaired.  Patience is required.  Any that are left can be filled in with clear dope and zinc stearate.  Concentrate on the bad spots with the dope and zinc stearate and will be surprised how fast they fill in.
Here is my Chizler done with House of Kolor Kandy Concentrate mixed with Randolph clear dope.
