  • June 15, 2025, 09:27:46 PM
Author Topic: Filler  (Read 1591 times)
Offline Bootlegger
Filler
« on: October 30, 2015, 01:50:19 PM »
 I need to fill some cracks in balsa that is over foam, so I need something that will not attack the foam.
 What are you using and where do you get it, other than the hobby shop?
    Thanks a lot...
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: Filler
« Reply #1 on: October 30, 2015, 06:44:32 PM »
Hi Gil,
I generally use light weight spackling compound.  It will fill the crack and prevent dope from getting to the foam.
Offline Bootlegger
Re: Filler
« Reply #2 on: October 31, 2015, 10:29:29 AM »
 Thanks Bill I got some today.....
Gil Causey
AMA# 6964
