  • July 12, 2025, 05:23:12 PM
Author Topic: filler  (Read 1406 times)
Offline Bootlegger
filler
« on: November 30, 2010, 12:00:54 PM »
I am building an O/T stuntship and the tail surfaces are 1/8" balsa, I don't want to have it looking like a pretzel by using dope.
 I am thinking about poly crylic instead.
 I plan to coat one end top and bottom, and when dry do the same to the other end. When dry put the second coat on, then spray primer on to seal the wood better.
 Does any one have a better idea?
 Thanks, Gil  y1
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: filler
« Reply #1 on: November 30, 2010, 01:09:00 PM »
I would use epoxy, Poly is water based and still could lead to warping the thin control surfaces IMHO
Re: filler
« Reply #2 on: November 30, 2010, 01:51:58 PM »
I've built a lot of solid-balsa 1/2-A ships, with 1/8" thick for the wings and non-tautening dope for finish.  I haven't had a problem with warping.
I wouldn't use content-weight wood for the stab, though, unless the plane is pretty darn small.
Re: filler
« Reply #3 on: November 30, 2010, 05:16:27 PM »
Go with the dope but put some of the Flex-All in it.
Don
Offline Ward Van Duzer
Re: filler
« Reply #4 on: December 01, 2010, 09:17:07 AM »
Use firm, (not rock hard) C-Grain wood...No problemo
Built 3 El Diablo elevators this way. Nary a warp!
W.
Offline Bootlegger
Re: filler
« Reply #5 on: December 01, 2010, 04:14:56 PM »
   Thank ya' guy's, I knew that the answer's would be here.  Thank's again... #^
Gil Causey
AMA# 6964
