  • June 16, 2025, 11:54:14 AM
Author Topic: Aaarrrg!  (Read 1771 times)
Dwayne
Aaarrrg!
« on: April 11, 2019, 06:17:32 PM »
So what's best for panel lines on $kote I asked, why a Sharpie they replied, cool should I shoot some clear over top I asked, why yes you should shoot some clear over top they replied, so I shot some clear over top, if I ever run into "they" I'm going to bop them in the nose.  LL~ HB~>
Re: Aaarrrg!
« Reply #1 on: April 11, 2019, 10:06:14 PM »
 FWIW I've used the Sharpies with success. When it came time for clear I started by gradually building it up with several light "dry" coats. A bunch of them first, allow to dry thoroughly, then take a big breath and give it one good final coat without going to too crazy with it.
Re: Aaarrrg!
« Reply #2 on: April 12, 2019, 12:09:04 AM »
I've successfully used a sharpie using about the same method as Wayne. However I also discovered the sun fades sharpie markers rather quickly.
Re: Aaarrrg!
« Reply #3 on: April 12, 2019, 09:45:32 AM »
I use Micron pens with Mylar ink. But pretty much the same as what Wayne said.
Re: Aaarrrg!
« Reply #4 on: April 12, 2019, 09:46:25 AM »
My question is:  Did you wipe the surface down good before the Sharpie application?   Also do one area at a time.  I have to wear gloves when I do some thing like this as my hands have oils as well as the surface of MonoKote. ???
Re: Aaarrrg!
« Reply #5 on: April 12, 2019, 10:02:21 PM »
 Yeah, I've noticed the same.
Dwayne
Re: Aaarrrg!
« Reply #6 on: April 13, 2019, 06:18:44 AM »
All fixed and looking quite "sharp" (see what I did there?  <= ) if I do not say so myself. There's 2 lightly misted coats so far and all is well.
Thanks for the help.
 y1 #^ H^^
Re: Aaarrrg!
« Reply #7 on: April 13, 2019, 10:48:03 AM »
 y1 #^ H^^
Looking good.  If you find "Them" I get seconds!
Re: Aaarrrg!
« Reply #8 on: April 13, 2019, 08:43:25 PM »
 y1 #^ H^^
 Looks great! How did you get rid of the previous mess?
Dwayne
Re: Aaarrrg!
« Reply #9 on: April 15, 2019, 06:54:47 PM »
It's Monkote  no need to worry about going though the finish so I used thinners, came right off real easy.
