  • July 29, 2025, 01:44:29 PM
Author Topic: Electric powered airplane finishes  (Read 1130 times)
Offline Mike Rogers
« on: July 06, 2025, 02:23:16 PM »
Hello everyone.
After many years away from the hobby my knowledge of modern finishing techniques needs some updating.
I recently started building a gas powered airplane which after some practical considerations has become an electric powered build. I started with the old school method of using dope, tissue and talc. As of now the wing, flaps and tail are in talc and ready for a blanket covering coat. Normally I would continue with some Randolphs silver followed by whatever colors I wish to use for base and trim and then the final clear coats. In the past my 600-650 square airplanes gained approximately 3 1/2-4 ounces after applying silver, base, trim and clear coats.
Suggestions would be most appreciated as to any alternative finishing type and technique that could be used that's a better way to go than finishing up with dope.
Thanks, Mike
« Last Edit: July 06, 2025, 04:04:12 PM by Mike Rogers »
Re: Electric powered airplane finishes
« Reply #1 on: July 06, 2025, 08:09:05 PM »
Given that you have started with dope, I would finish with dope. There are alternative finishes, but I think you would want to start with the base coat and go up.
Besides, one of the special things about electric is that you're in the pits next to people fueling up their sliders. And sometimes, fuel will spill on your airplane. So you probably still want something that's at least fuel resistant, if not fuel proof.
« Reply #2 on: July 06, 2025, 08:12:22 PM »
Thank you for the comment about weight gain when putting on silver and all the rest. I have an electric that's been on the bench for way too long, so it is going into the air without even silver on it. My intent is to finish the finish later. It is nice to know how much weight it will gain in the process.
« Reply #3 on: July 07, 2025, 09:13:04 AM »
Mike,
One alternate approach is to MonoKote the wing and tail surfaces and paint the fuse. This saves a lot of weight. Allen B used this method as his wife had a reaction to dope fumes. He used Rustolum top coat (if you do this you need to let the Rustolum cure out at least two weeks before flying). You could do the same with dope and do a 2K clear topcoat on the paint.
Best,    DennisT
« Reply #4 on: July 07, 2025, 04:48:27 PM »
Polishing, yes.  Flying - why?
« Reply #5 on: July 07, 2025, 06:26:16 PM »
I once had a fellow pilot come up to me and sheepishly admit that while fueling up his slimer the fuel line has popped off and sprayed fuel all over a nearby world champion's electric plane.
That's why
Maybe go ahead and fly the next day, but give it a couple of weeks to cure before allowing it in the company of slimers
