  • June 14, 2025, 03:22:45 PM
Author Topic: Randolph clear dope - blushing and gloss..  (Read 9354 times)
« on: September 18, 2008, 01:09:42 PM »
According to Randolph's (Brodak's source) instructions,
"If blushing is an issue, wait until the humidity is under 50%".
Well Hurricane Ike was passing though, and even on the North Coast it was 100% humidity and rain for four days.  But I have to make timing for a contest so I painted it anyway.  It blushed like crazy.  But when it got down to 45%, I gave the plane three coats of clear with a goodly dose of retarder and it all went away.  Problem solved.
Note: I'm in a free fight club where light is right.  So we don't mind seeing some light through the silk, paint, and maybe the wood.
One question:
Does anybody get a good gloss finish with Randolph clear sprayed on?
Most of my planes are OK with a matte or semi-gloss finish, but if I ever do want gloss, can it be done with Randoplh?
Re: Randolph clear dope - blushing and gloss..
« Reply #1 on: September 18, 2008, 01:51:23 PM »
Yea, you have to wait awhile for the clear coat to gas off enough to sand it out and rub it up to get a really good gloss finish. I use Randolph's clear. I get it by the gallon from aircraft supply places. Good stuff, though thick as maple syrup until it's thinned. A lot. A really large amount.
« Reply #2 on: September 19, 2008, 07:12:50 AM »
I buy mine at the ariport, too.  I usually get a gallon each of dope & thinner.  I've also got both tautening & non-tautening dopes.'
I'll try that super-thin retarded formula on another plane and see if it shines up better.
« Last Edit: September 22, 2008, 10:34:11 AM by ama21835 »
« Reply #3 on: September 19, 2008, 11:36:21 AM »
>>retarted<<
Is that a tart that returned to the business?   LL~
