  • June 16, 2025, 03:06:49 AM
Author Topic: Monokote Lifting?  (Read 1031 times)
Offline Jerry Reider
Monokote Lifting?
« on: November 29, 2009, 09:15:56 PM »
I've found that on planes that have flat surfaces with Monokote on them that the Monokote seems to lift and get air bubbles as the plane ages.  I have a Brodak 38 Special that is about a year old and the Monokote is getting loose on the large flat surfaces like the horizontal stab, elevator and the back half of the fuselage.  I find that I can iron it back down and poke pin holes to release the air bubbles and then I take a moist cloth and go over the hot surface to press it down.  I used the Metallic Red, Monokote brand.  I'm wondering if using Balsarite or something else will make the Monokote stick longer.  I think that I've read that elsewhere.  My edges have all stayed on tight, it just seems to be the center areas that lift.  Maybe I should be stretching the film on the flat surfaes when I apply it like when I do the wings.
Jerry
Offline Bob Reeves
    • Somethin'Xtra Inc.
Re: Monokote Lifting?
« Reply #1 on: November 30, 2009, 10:23:34 AM »
Bout all I can tell you is the Monokote metalics suck. Even regular Monokote isn't what it once was. Most are switching to UltraCote, including me....
« Reply #2 on: November 30, 2009, 11:16:42 AM »
I'd have to agree with that.  I've found the UltraCote to be better.  The Metallic was hard to work with.  It's thicker and the wingtips especially, were a bear to get nice.  Overall the covering job got real nice but I struggled to get it that way.
« Last Edit: March 09, 2010, 01:28:25 AM by Jerry Reider »
Jerry
« Reply #3 on: November 30, 2009, 12:08:36 PM »
I tried Ultracoat on my new Nobler, I hate it, I'm going back to silkspan and dope.
