  • June 17, 2025, 01:36:30 PM
Author Topic: A note on tapes  (Read 2002 times)
A note on tapes
« on: October 06, 2013, 12:23:55 PM »
Well, I've always used 3M blue vinyl tape and Finesse pinstripping tape along with various other stuff like electrical tape, frisket and some other stuff. But Pete Peterson turned me onto use just 3M "Edge Lock" blue making tape. I am starting to really love this stuff. It's easy to work with, doesn't slip or move once down and really doesn't need any sort of sealing. And it's thin so it doesn't leave a lot of ridge.
Cool.
Offline Bootlegger
Re: A note on tapes
« Reply #1 on: October 06, 2013, 05:45:40 PM »
where kin a feller git sume?
8th Air Force Veteran
Gil Causey
AMA# 6964
James_Mynes
Re: A note on tapes
« Reply #2 on: October 06, 2013, 06:07:42 PM »
I've never tried it, but it gets bad reviews on Amazon. Expensive, too.
Re: A note on tapes
« Reply #3 on: October 07, 2013, 03:39:39 PM »
I buy it at the local Lowe's store. Just 3/4 3M Edge Lock masking tape. Works pretty well overall. I like the 3M vinyl stuff but it's pretty thick. The Edge Lock leaves a much smaller ridge. But you have to insure it's down. I had a couple of spots on the current plane that showed some very minor bleed but I didn't get it down well enough. Oh well, live and learn.
Offline Bootlegger
Re: A note on tapes
« Reply #4 on: October 07, 2013, 05:16:04 PM »
  Thanks Randy, Lowe's it is..
Gil Causey
AMA# 6964
Re: A note on tapes
« Reply #5 on: October 07, 2013, 06:34:22 PM »
I hope I'm not hijacking your thread: I want something like frisket paper, only more flexible and with about twice as much tack.  I find that when I'm in the mood to carve something out freehand the frisket works well, and seals down nicely, but requires multiple passes to get it to stay stuck.
Offline RogerGreene
Re: A note on tapes
« Reply #6 on: October 08, 2013, 08:50:14 AM »
I have used the Blue tape and IF you leave it on too long, over night or so, some of the sticky stays on the plane's surface and also it will pull off the paint. So beware of leaving the blue tape on tooo long....
Roger
Fly Stunt <><
AMA 435R
USAF Veteran 1962-66 SAC
Life is 10% what happens to you and 90% of how you react to it. FAA #FA3RFLPAN7
Re: A note on tapes
« Reply #7 on: October 08, 2013, 10:55:18 AM »
for the record, there are a LOT of different "blue" tapes,, Edge Loc is a specific type not to be confused with any other blue tape out there. I have seen "blue" tape at Harbor freight, Lowes, Home depot and the dollar store,, its not the same thing,,
Re: A note on tapes
« Reply #8 on: October 08, 2013, 12:10:12 PM »
It's not???
Well, I guess I can just s**t-can the cheap white tape and the blue sharpie, then.
Re: A note on tapes
« Reply #9 on: October 10, 2013, 05:43:04 PM »
For stuff like "Frisket" you might try Avery 8665 mask. It's actually an office product. I get it at Office Depot. I used to for doing checkerboard and such.
Hmmm.... checkerboard.
Re: A note on tapes
« Reply #10 on: October 10, 2013, 08:15:36 PM »
NOOOOOOO,,
Re: A note on tapes
« Reply #11 on: October 10, 2013, 09:31:15 PM »
 LL~
Re: A note on tapes
« Reply #12 on: October 12, 2013, 11:19:45 AM »
I have tried most tapes and always come back to drafting tape. I buy it in 3/4" wide rolls and cut what I need. It is medium tack, and I have never pulled up paint with it. I sometimes use a heat gun to remove it just to keep the sticky on the tape, but it will clean off with denatured alcohol. I do run a couple of coats of clear dope along the edge with a small brush to seal it from the colors.
