  • June 16, 2025, 11:26:08 PM
Author Topic: Dreadnought with improvised wing joints  (Read 2363 times)
Offline Jorge de Azevedo
« on: February 19, 2013, 06:52:21 AM »
Re: Dreadnought with improvised wing joints
« Reply #1 on: February 19, 2013, 06:59:32 AM »
Very Very Nice!!!
Derek
« Reply #2 on: February 19, 2013, 07:31:22 AM »
Jorge,
Looks great!!! Are the graphics on the fuse paint or vinyl? If vinyl who cut them and how did you apply and what did you clear over them with?
Again ship look Awesome.
Best,       DennisT
« Reply #3 on: February 19, 2013, 07:39:43 AM »
Nice sysyem.
Great looking model also.
Question.
R/C guys use a single tube for attaching wings. I've had a few models like this and still have a few.
We snap roll these models and some are large. They stay together. My old Staudacher was 80.5" in span. Not large but not small either.
Tube, small screw for each wing and a couple of dowel pins.
Why won't this attachment method work for CL?
Charles
« Reply #4 on: February 19, 2013, 07:43:55 AM »
Nice sysyem.
Question.
Charles
Because thatis where the bellcrank and leadouts go...
Derek
« Reply #5 on: February 19, 2013, 07:55:37 AM »
Derek
Derek,
I don't understand the leadouts being an issue? The bellcrank can be placed anywhere. So they say.
Has anyone made attempts to use the simple tube method?
And failed.
Charles
« Reply #6 on: February 19, 2013, 08:35:51 AM »
Derek,
And failed.
Charles
Yep, just put the bellcrank anywhere, doesn't matter.
Derek
« Reply #7 on: February 19, 2013, 08:55:33 AM »
Derek
derek,
OK, then why isn't there a wing attachment method, using a simple tube, like in R/C?
Charles
Offline RC Storick
« Reply #8 on: February 19, 2013, 09:08:19 AM »
Derek
 LL~ LL~ LL~ LL~ LL~ LL~
« Reply #9 on: February 19, 2013, 09:46:30 AM »
Ah, you can put the bellcrank anywhere. but you also have to think about the drag on the leadout mechinism. If the bellcrank is at too severe an angle to the leadout position, you will have a plane that hunts (among other problems). I suppose you could build a system that has some sort of roller at the leadout position that would allow for a severe angle, but seems a lot of work unless you are overcoming a specific problem.
Since there are all sorts of systems for plug in wings, why re-invent the wheel?
Oh, an the system presented here is interesting. I imagine it will work fine if the anchors in the fuse are secure.
Offline RC Storick
« Reply #10 on: February 19, 2013, 10:08:53 AM »
Side note. I can't remember what year it was but I was almost hit by a engine that flew out of a plane. That's the same year of the big winds and I caught a P51 as it almost hit me in the face when the wind picked it up the reason I mention this is that both guys were from Brazil. Quite a fun bunch. Same year the wing separated from the fuse on one plane.
The airplane here looks like it will be secure however my mind did question the center spar and joint. Only time will tell.
Offline MarcusCordeiro
« Reply #11 on: February 19, 2013, 12:49:45 PM »
Remember the names of the guys?
When and where?
Would like to know this....
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
« Reply #12 on: February 19, 2013, 02:28:07 PM »
Aaah yes, Robert - the year of the big wind!  Wow, what a zoo that was on finals day! ~^  And yes, the Brazilian contingent added so much to that fun.  I hope they come back soon!
Meanwhile, the workmanship on this plane is really fine!  Way to go.
« Reply #13 on: February 19, 2013, 03:11:22 PM »
Robert,
I agree. Seems the aluminum tubes could take the torque of the wing. The bolted areas are usually just supposed to insure the wing doesn't move on the supports, not take any of the flight stresses. I wasn't all that thrilled with the setup, but as you said, time will tell. Could be he's used this method numerous time without problems, but it's not a system I would be happy with.
« Reply #14 on: February 19, 2013, 03:49:29 PM »
Aces High!
Offline ash
« Reply #15 on: February 19, 2013, 04:42:29 PM »
Robert,
Further agreed.
I would suggest looking very carefully for cracks around those screw tabs before and after every flight.
Online Lauri Malila
« Reply #16 on: February 20, 2013, 03:01:02 AM »
[quote author=Avaiojet ..
Question.
We snap roll these models and some are large. They stay together. My old Staudacher was 80.5" in span. Not large but..
[/quote]
Of course there is the issue with control system, but also structurally, a single thick tube is never ideal. It's used in RC models only because it's easy to make.
The problem with a tube is that there is the smallest amount of material where you need it the most (in top & bottom to handle the tension and compression), and unnecessarily much material the closer you get to the center line.
It's kind of a mirror image of a good I-beam. But it seems to work with RC people, they are not so anal about weight and intelligent use of construction materials. L
Ps. I must add that in my free flight gliders, the wing joiners are 2x 1/4" dia. solid spring steel bars and they bend far too easily. Now we're looking for a replacement in carbon, perhaps with a square section.
« Reply #17 on: February 20, 2013, 03:59:50 AM »
Jorge,
Best,       DennisT
Dennis,
Thank you,
It is all painting. I utilized vinyl as a mask to paint this, it was cut in a plotter.I have photos step by step form this painting including wings not shown here.
The colors was polyester paint with clear PU  PPG over.
« Last Edit: February 20, 2013, 06:36:11 AM by Jorge de Azevedo »
« Reply #18 on: February 20, 2013, 04:26:50 AM »
Very Very Nice!!!
Derek
Thank you, Derek.
I love all your paintings.
« Reply #19 on: February 20, 2013, 04:37:15 AM »
Robert,
I remember this, the guys were using American wing joints.
 LL~ LL~ LL~ LL~ LL~
« Last Edit: February 20, 2013, 06:32:21 AM by Jorge de Azevedo »
Offline RC Storick
« Reply #20 on: February 20, 2013, 09:23:32 PM »
Robert,
 LL~ LL~ LL~ LL~ LL~
When i caught that airplane its was straight vertical and I caught it with no damage. What luck for both of us. Me for not getting hit in the face and him for still having a airplane in tact. I wish I would have been closer to Bobs crossfire that one year a dust devil flipped it over.But I was at least 10 foot up wind.
