  • June 18, 2025, 04:27:15 AM
Author Topic: Dyeing Polyspan  (Read 1194 times)
Offline Larry Renger
Dyeing Polyspan
« on: November 15, 2013, 05:30:18 PM »
Yes you can!  y1
Usually people put dye in the dope they apply to Polyspan, but what do you do if you want to do SLC over Polyspan as discussed in this forum?
AHA! I have the answer. rockler.com sells Transtint dyes in a wide variety of colors. You put about ten drops into 2 oz of denatured alcohol and spray the Polyspan and it is colored!! I expect that adding it to dope over that would kick up the intensity, or for my next project, the top film will be transparent colored ultralight parkflyer type film.
I expect to see really intense transparent glow in the sky!  #^
OBTW, this should work just fine on raw balsa, silkspan or Japanese tissue. I expect it is like spray Magic Marker.
« Last Edit: November 15, 2013, 05:56:33 PM by Larry Renger »
Offline Bootlegger
Re: Dyeing Polyspan
« Reply #1 on: November 18, 2013, 08:56:09 AM »
   Got pictures???  Thanks
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: Dyeing Polyspan
« Reply #2 on: November 18, 2013, 01:27:16 PM »
It looks like polyspan except yellow. When I have a model completed, then photos!
Offline Bootlegger
Re: Dyeing Polyspan
« Reply #3 on: November 18, 2013, 01:37:55 PM »
  I'll be waitin with "baited breath"   Thanks Larry
Gil Causey
AMA# 6964
