  • June 15, 2025, 03:22:00 AM
Author Topic: KlassKote sprayed onto Oracover  (Read 1333 times)
Offline Mike Quinn
« on: August 20, 2021, 11:52:57 PM »
Hi
I'm planning on covering my models wing and tail in Oracover (Profilm).  I've successfully sprayed Oracover with Oracolor in the past but wanted to use up my stocks of KlassKote rather than remortgage the house to by more Oracolor.
Anyone used KlassKote on Oracover before?  I know I'll have to abrade the areas to be covered as with Oracolor but just wondered if anyone else had used KK successfully in this way.
Cheers
PS Fuselage will be glassed and sprayed
« Last Edit: August 21, 2021, 02:24:22 AM by Mike Quinn »
Offline Dan Berry
Re: KlassKote sprayed onto Oracover
« Reply #1 on: August 21, 2021, 03:16:30 PM »
I have applied it onto Ultracote.  Narrow band at fuselage with Ultracote on wing and stab. It staywed in place.
Offline Mike Quinn
« Reply #2 on: August 25, 2021, 02:42:23 PM »
Thanks Dan ... probably best just to give it a go !
Cheers
« Reply #3 on: August 25, 2021, 06:40:36 PM »
Just clean the surface real good and wear gloves. D>K
