  • June 18, 2025, 04:26:08 AM
Author Topic: Airbrush  (Read 5010 times)
Rick_Huff
Airbrush
« on: December 17, 2015, 02:34:14 PM »
Can anyone recommend a good airbrush for less than $100?  My next plane will have a camouflage paint scheme and it seems like an airbrush would work well to apply it.
Rick
Offline Mike Haverly
Re: Airbrush
« Reply #1 on: December 17, 2015, 03:14:05 PM »
I've been using one of these for about 15 years.  The pick up tube for the paint needs to be changed to copper or brass, other than that it has worked well.  Some parts and bottles are available at the local Hobby Lobby.
http://www.tcpglobal.com/PAS-H-SET_2.html?sc=113&category=3601391#.VnMzYP1Ihpg
Re: Airbrush
« Reply #2 on: December 17, 2015, 03:15:09 PM »
 a good "entry level" airbrush that will serve you very very well forever, and has parts available, is the Paasche VL
its been around for decades,, and is extrememly well suited for modeling
here is a quick google
https://www.google.com/search?q=paasche+vl&ie=utf-8&oe=utf-8
Re: Airbrush
« Reply #3 on: December 17, 2015, 10:35:27 PM »
Yup, can't beat it for the money. I've had mine for years now. Works perfect every time.
Rick_Huff
Re: Airbrush
« Reply #4 on: December 18, 2015, 09:49:36 AM »
Ok, the Paasche VL it is.  Thanks for the help,
Rick
Offline jfv
Re: Airbrush
« Reply #5 on: December 21, 2015, 03:04:52 PM »
This one got great reviews from someone on this forum but I can't find the thread.  I bought one but haven't had a chance to use it.
http://www.harborfreight.com/deluxe-airbrush-kit-95810.html
Jim Vigani
Offline JIM Nordin
Re: Airbrush
« Reply #6 on: December 21, 2015, 05:01:46 PM »
IWATA  eclipse
  it's the work horse of  the custom paint world
Re: Airbrush
« Reply #7 on: December 21, 2015, 06:46:22 PM »
IWATA  eclipse
its also like 150 bucks,, the VL can be had for half that,, and is for the intents and purposes asked about, certainly viable,,
the Iwata is a great brush, I have both,, I grab my Iwata mostly,, granted my Iwata is a bit further up the pay grade,, but My VL gets used whenever I want to spray areas as opposed to small lines,, or for tshirts,,
I still stand by the best answer for the OP question is the VL,, I cannot in good faith recomend the Harbor Fright gun,, they are just to inconsistant
Offline JIM Nordin
Re: Airbrush
« Reply #8 on: December 21, 2015, 07:02:31 PM »
Amazon has them for $114 . Right now. They can be had for $100 if you shop around
Re: Airbrush
« Reply #9 on: December 21, 2015, 09:06:53 PM »
fair enough,, we all have our own opinions, I was actually expecting someone to beat me up about my comments on the Harbor frieght gun,, it usually happens LOL
Offline JIM Nordin
Re: Airbrush
« Reply #10 on: December 21, 2015, 11:37:37 PM »
My first AB was a master from tcpglobal amd I learned  a lot with it . About half of a IWATA . There kinda hit and miss though . Nothing wrong with the VL  . Just giving options
Offline Fredvon4
  • Central Texas
Re: Airbrush
« Reply #11 on: December 22, 2015, 08:40:19 AM »
Rick I see most have recommended good airbrushes and my vote is also the VL
I have to add they are only good for very fine and small detail, not any large areas of fill
You mentioned a camo paint scheme and perhaps you might like to use a 4oz finish detail air gun instead of, or in addition, to an airbrush
These can range from $400 down to the very good for the price Harbor freight version for $19~$49....Sparky has a video of the HF el cheapos
I have several of the different sizes of HF paint guns and for the price they do as good a job as my much more expensive Binks detail guns ( I used to custom paint cars and motorcycles)
There is a technique for using foam shapes to soften the lines from one color to the other color... if that is the effect you need
typical masking will leave a sharp line between colors and some schemes are like that. But for soft lines between colors the mask is tall off the surface and painted from behind the line leaving a soft transition.  I use closed cell thin foam 1/8 to 1/4 thick  found in some packaging I save for this use. I cut to shape, thin layer of rubber glue and set in place
Fred von Gortler IV
Rick_Huff
Re: Airbrush
« Reply #12 on: December 22, 2015, 11:16:50 AM »
Thanks Fred for the technique, I'll give it a try.
Rick
