  • July 13, 2025, 05:34:35 AM
Author Topic: Does monokote stick to epoxy  (Read 1719 times)
Offline John KruziK
« on: July 11, 2010, 08:52:27 PM »
Will monokote stick to epoxy finishing resin? I used it to reinforce center of wing. Thanks John
AMA 874027
Re: Does monokote stick to epoxy
« Reply #1 on: July 12, 2010, 09:40:17 AM »
Clean the surface real good and then hit it with 400 grit or finer sandpaper.  It least that is what I have done. H^^
Offline John KruziK
« Reply #2 on: July 12, 2010, 04:31:01 PM »
thanks Doc
AMA 874027
« Reply #3 on: July 12, 2010, 08:32:08 PM »
you have to be careful with the heat setting too - because the epoxy does not let the heat dissapate - you will end up with a lot of shrinking in one area if you leave the iron on there too long - also - the heat weakens the bond of the epoxy - so less is more when it comes to applying it.
Proviously, I have coated the epoxy with balsaloc or PVA glue to give the "cote something to tack to at a lower heat setting......
Offline Greg L Bahrman
« Reply #4 on: August 04, 2010, 10:03:07 PM »
Too much heat and it will bubble under the monocoat. I've only done small areas with low heat and hand rubbing with a rag. Sometimes have to go over it 2 or 3 times. But once once stuck down it's almost impossible to get it up. I've only done wing center sections and a couple of fuse noses.
Greg Bahrman, AMA 312522
Simi Valley, Ca.
Offline Terry Bolin
  • Havin' the time of our lives!
« Reply #5 on: September 22, 2010, 08:46:51 AM »
I do this on the RC planes alot where I use Epoxy and nylon tape for a wing joint. After sanding the epoxy smooth with a block sander , I use spackle compund and rubb it with a credit card over the sanded epoxy area and use spackel to blend the edge where the epoxy ends and wood begins. it turns out nice but like they said: Use lower heat and go slow small areas... it'll turn out fine! good luck.
\Terry
