  • June 28, 2025, 03:54:26 AM
Author Topic: do you spray clear over trim...  (Read 1136 times)
Offline John KruziK
« on: January 14, 2011, 07:34:11 PM »
Does it make sence to spray clear over adhesive trim stripping to keep it from lifting
AMA 874027
Re: do you spray clear over trim...
« Reply #1 on: January 14, 2011, 09:07:02 PM »
 Yes, definitely. Or maybe I should say maybe. ;D
 Done properly, putting clear over trim and graphics will definitely help things last longer. I do this on practically all of my models. Depending on what products you are using though you must be very careful not to ruin the vinyl or whatever trim you're using. For instance, if you go too heavy right off the bat with the clear, the thinner can and will easily attack and wrinkle the vinyl. This will really ruin your day. You can get away with it though by fogging on several light, dry coats, and letting each of them dry as you build up to finally going with a couple of heavy coats at the end.
« Last Edit: January 14, 2011, 10:22:47 PM by wwwarbird »
« Reply #2 on: January 15, 2011, 08:01:54 AM »
2 Mist coat passes Should do the trick.
Then layer on your heavy. - He's 100% Spot on too heavy 1st up and your STUFFED!
« Reply #3 on: January 15, 2011, 12:41:54 PM »
Depends on materials. If you are talking Monokote and Trim Coat then you may or may not get adhesion. I had some success with shooting catalyzed polyurethane over iron on plastic coverings, but I've also had it peel off. Better luck if the covering is something like textured like Coverlite.
« Reply #4 on: January 16, 2011, 08:36:19 PM »
I have had no trouble brushing clear dope over decals and vinyl lettering. I do coat my ink jet decals with dope for a fixitive before applying them to the plane, and then just brush the clear over everything. I have never used auto clear, so I don't know how that would work.
