  • July 20, 2025, 01:45:01 AM
Author Topic: Do not try this at home! (or anywhere else)  (Read 1891 times)
Offline Larry Renger
« on: March 29, 2018, 11:53:39 AM »
I like Mod Poge adhesive for adhering tissue, film, carbon veil, etc.  It is kind of thick. I thought I'd try an experiment to thin it without adding more water and maybe making drying quicker.  :!
So I mixed up some Mod Poge with denatured alcohol.  Not a good plan. It actually ended up a thick gel.  I tried doing a test sample covering, and it did work, but it was worse for brushing than the original glue.  HB~>
Plus, the brush was a b%$^h to clean.
I guess water is still the thinning liquid to use.  :(
Re: Do not try this at home! (or anywhere else)
« Reply #1 on: March 29, 2018, 01:39:23 PM »
Thanks or the heads up. H^^
Bu the way, I tried the Elmers White glue.  It didn't work. ???
Offline MikeyPratt
« Reply #2 on: March 29, 2018, 05:19:41 PM »
Hi John,
Try Elmer’s glue stick, it worked for me and way better than the Mod Poge.
Later,
Mikey
Offline dave siegler
  • sport flier
    • Circlemasters Flying club
« Reply #3 on: April 03, 2018, 03:35:04 PM »
I recently tried water based polyurethane and really like that for tissue and silkspan.
Worked good over foam easier than glue or wall paper paste.
Dave Siegler
NE9N extra class
AMA 720731
Offline billbyles
« Reply #4 on: May 02, 2018, 04:11:57 PM »
Hey Larry,
I know...just use Klasskote clear to activate the Klasskote red - you get a terrific gloss that way!
Bill Byles
AMA 20913
So. Cal.
