  • June 16, 2025, 03:06:49 AM
Author Topic: How Do You Paint [i]Cloth[/i] Hinge Lines . . .  (Read 1351 times)
Offline Larry Fulwider
« on: December 06, 2009, 05:35:07 PM »
. . . so they don’t come out all goobery like the second pic?
OK at the clear stage! (first pic). Top coat is LustreKote over LustreKote white primer.
Only solution I see is do one side, and wait ‘til it dries?
   Larry Fulwider
Offline billbyles
Re: How Do You Paint [i]Cloth[/i] Hinge Lines . . .
« Reply #1 on: December 07, 2009, 02:58:00 PM »
   Larry Fulwider
Hi Larry,
I have never had that problem when using a butyrate dope finish nor when using a two-part polyurethane automotive clear topcoat.  I have a feeling that using the LustreKote enamel with its slower drying properties may be what is giving you the problem.
Bill Byles
AMA 20913
So. Cal.
« Reply #2 on: December 07, 2009, 03:26:24 PM »
Hi Larry,
 . . . I have a feeling that using the LustreKote enamel with its slower drying properties may be what is giving you the problem.
Bill --
Thanks, and I'll bet you're right. I suppose letting it dry with the elevator drooping down would only make it raggedy looking on the bottom. Hey, it's a half-fast (phonetically) workable solution!
    Larry Fulwider
