  • June 28, 2025, 03:08:14 PM
Author Topic: Dents in silkspan/dope  (Read 4624 times)
« on: May 15, 2023, 02:23:47 PM »
So, I put some dents into my nice doped wing.  The picture makes them look better than they really are.  This is silkspan over an open bay, painted with Sig & Certified butyrate dope, bottom to top.
Is there a way to take the dents out?
Re: Dents in silkspan/dope
« Reply #1 on: May 15, 2023, 03:23:57 PM »
My finishes are not anything to write home about, or anywhere else for that matter, but I have "sort of" removed some dings by injecting a very small amount of water under the ding then using a monokote iron to heat it.  Got the idea from removing benchmarks in raw balsa before covering.  Dings in polyspan respond to heat as well, as does MonoKote.  Plan "B" is a well-placed decal over the Boo Boo.
« Reply #2 on: May 15, 2023, 06:08:00 PM »
There is no "under" under the ding -- it's over an open bay.
« Reply #3 on: May 15, 2023, 08:35:55 PM »
Plan "B"
I have racked my brain for another solution that does not end up looking worse than the ding.  I assume you have tried damp heat.  Maybe some tauting clear in the dent to soften it up followed by a blast from a MonoKote gun.  Too bad it is not pollyspan.  Anyway, Top -  Put a little "No Step" sticker over it.  Bottom - ignore it.
« Reply #4 on: May 15, 2023, 09:08:10 PM »
Plan "B"
Moist heat was the first thing I was going to try without feedback.
Offline kevin king
« Reply #5 on: May 16, 2023, 12:49:46 AM »
If I were you I would fill up an airbrush with 60/40 thinner/clear dope and fill the dents with clear, let dry, sand and then polish.
« Reply #6 on: May 16, 2023, 06:49:21 AM »
Tim - Overall where is this.  The picture leads you to believe it is at the flap joint on the outboard bottom.  And, a little off subject, what is the screw for.  I am always fascinated by innovative ways to adjust flaps.
« Reply #7 on: May 16, 2023, 08:15:46 AM »
That's a radio hatch on a scale plane whose throttle is run with a 2.4GHz radio.
Offline Miotch
« Reply #8 on: May 18, 2023, 09:04:27 AM »
I have one in the side of my current build where my son picked it up over an open bay.  I've decided to live with it or put a sticker over it.  Whenever I try to fix a minor problem, I almost always create a major problem.
« Reply #9 on: May 18, 2023, 11:00:00 AM »
Words that should be on a plaque over every workbench!  y1
« Reply #10 on: July 25, 2023, 01:22:54 PM »
Very late reply...just brush or blow on a coat of clear dope-will shrink right up.
Offline Miotch
« Reply #11 on: July 26, 2023, 08:52:39 AM »
I looked the other day and the one I had on the fuselage of my plane finally just pulled itself smooth.  Nature can fix almost anything better than I can.
« Reply #12 on: July 26, 2023, 12:52:27 PM »
Dope shrinks until it's too brittle to do anything but crumble-sometime that's for years.  A little heat application,  perhaps just setting the airplane in the sun or a hot car for a few hours will pull out many dents and wrinkles.  When it becomes too dry to shrink much an application of a little fresh dope will reinvigorate the old dope some and make it shrink more.  You can also give new life to old covering the same way.  A coat of well-retarded and thinned clear will soften the finish and give it another life in most cases.
« Reply #13 on: July 26, 2023, 01:35:20 PM »
I’d try in order:
1. A brief touch with a Mono Kote iron
2. A dab of tautening dope
3. A glob or two of dope with zinc srearate
4. Spot putty
