  • July 31, 2025, 06:02:34 AM
Author Topic: klasskote resurrection  (Read 10675 times)
Offline BillLee
« on: November 14, 2024, 12:04:34 PM »
I have a can, nearly full, of KlassKote that was opened some time back and with which I painted one model. I cleaned the can threads and the cap and tightly sealed it up. Now today, the paint in that can is so thick I couldn't use it, the consistency of thick tar.
I hate to throw away an almost full can of that terribly expensive paint. What do I do to resurrect it?
Bill Lee
« Last Edit: November 14, 2024, 02:03:40 PM by BillLee »
Bill Lee
AMA 20018
Offline BillLee
Re: klasskote resurrection
« Reply #1 on: November 14, 2024, 02:03:06 PM »
Delete
Bill Lee
AMA 20018
« Reply #2 on: November 14, 2024, 05:20:16 PM »
If you can mix it, it will cure. You'll have to use some thinner after mixing. I don't know of any way to reconstitute it before mixing. You might experiment with heat. I know epoxy resin can crystalize and thin out again with heat. Put the can in a pot of hot water and let soak and repeat. I've used some pretty thick Superpoxy decades old and it was ok. Good luck.
MM :)
Offline bill bischoff
« Reply #3 on: November 14, 2024, 08:26:31 PM »
What color? Maybe I have some you can use.
BB
Offline BillLee
« Reply #4 on: November 14, 2024, 09:18:16 PM »
It is a can of bright red that i had used to paint the red F2A model. That's all that had been used. Turns out i had another new can that KK had mistakenly sent me when i ordered the dark red for the Slow Rat,  so i was able to get the painting done. (The red F2A model again with revised cowl.) But I sure hate to throw away what is essentially a full can.
Bill Lee
AMA 20018
Offline Larry Renger
« Reply #5 on: November 15, 2024, 08:20:31 AM »
Contact KlassKote and ask them.
