  • June 16, 2025, 02:09:43 PM
Author Topic: paint  (Read 1428 times)
Offline roger
paint
« on: October 14, 2010, 04:56:20 PM »
what is the best way to paint a 1/2 a plane so as to keep weight down? plane is a twin with a 341/2 inch wing, got to keep it lite its a scale job. would rustoleum be a good choice?
Offline Gene O'Keefe
Re: paint
« Reply #1 on: October 18, 2010, 07:41:59 AM »
Rustoleum would work - just be careful of the dark colors like dark blue or black - thay have a tendency to never dry thoroughly.
Gene O'Keefe
AMA 28386
Offline Posthole_digger
Re: paint
« Reply #2 on: October 18, 2010, 09:10:49 AM »
 Rustoleum  is very heavy.
After all, model aviation is not a matter of life or death - its more important than that!
Offline roger
Re: paint
« Reply #3 on: October 19, 2010, 06:05:19 PM »
ok so now what
Re: paint
« Reply #4 on: October 19, 2010, 07:48:32 PM »
I guess it's back to dope.
  • Gravitywell
Re: paint
« Reply #5 on: October 20, 2010, 11:19:15 AM »
Here's a baby Bipe Ringmaster I finished it with a few strips of coloured tissue and a black, fine tip Sharpie for panel lies.  Then the whole plane was given two coats of Diamond Varathane, sanding after the first coat with 300 grit.  If you want, you can use the water based Varathane as well.  Its lite as a feather and dead easy to do. H^^
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
Offline louie klein
Re: paint
« Reply #6 on: October 20, 2010, 01:48:17 PM »
Gravitywell, is it fuel proof?---LOUIE  ???
  • Gravitywell
Re: paint
« Reply #7 on: October 20, 2010, 04:14:36 PM »
It is absolutely fuel proof.  I have used Varathane to protect decals on larger ships, not cleaned them for far too long, and no penetration or lifting.  Besides....its my experience that a 1/2A ship never outlasts its finish! LOL
Glenn Reach
Westlock, Alberta
Re: paint
« Reply #8 on: October 21, 2010, 06:43:54 AM »
Is it available in other than gallons? Our local Lowe's only has it in gallons.
  • Gravitywell
Re: paint
« Reply #9 on: October 21, 2010, 10:52:27 AM »
Yes it is.  Check other lumber yards or hardware stores.  It comes in pint tins and one that is about 1/2 pint even.  I always have a pint tin laying around for other woodworking projects I am forced to do by my daughters and wife.  They are quite mean that way! %^@ H^^
Glenn Reach
Westlock, Alberta
