  • August 05, 2025, 04:07:13 AM
Author Topic: Randolph dope  (Read 4104 times)
Offline James Mills
Randolph dope
« on: April 05, 2020, 06:29:34 PM »
Looking at the Randolph color dope on Aircraft Spruce trying to find as close of a match to Miss Ashley Red as I can.  Any suggestions?
AMA 491167
Re: Randolph dope
« Reply #1 on: April 05, 2020, 07:24:56 PM »
I would take my color sample to Walmart or whoever carries the complete line of Krylon aerosol can colors near you, and try to match it up. Krylon offers a few reds.
Or, you could try Tamiya Paint, also in aerosol cans or jars for air brush.
Re: Randolph dope
« Reply #2 on: April 05, 2020, 10:02:47 PM »
  If Randolph's doesn't have a match, take a sample to an auto paint supply store and have them match it and supply the pigment. Then just add the pigment to your clear Randolph's. The big problem might be in finding one that's open, as they might not be "essential.". If it's electric you can shoot it in anything you want so they can supply it in lacquer. You can use their clear also with no compatibility issues.
Offline Mike Haverly
Re: Randolph dope
« Reply #3 on: April 05, 2020, 10:34:40 PM »
I've done what Dan mentioned many times.  Just be sure to ask for pigment with no binder.  The place I go to will mix as little as 1/2 pint, added to clear dope you a can probably get a quart of red.
Offline James Mills
Re: Randolph dope
« Reply #4 on: April 05, 2020, 11:19:37 PM »
The O'Reillys near me is still open and they are a paint store.
James
AMA 491167
Offline Steve Dwyer
Re: Randolph dope
« Reply #5 on: April 06, 2020, 11:40:27 AM »
James,
You might want to call Randolph about matching a color. The last time I talked to them about compatibility and their tautening butyrate I believe they said they could mix a custom color. They, however, may have thought I was painting a 50 ft span aircraft and not a model, give them a call.
Offline James Mills
Re: Randolph dope
« Reply #6 on: April 06, 2020, 09:29:57 PM »
James,
AMA 491167
Offline kevin king
Re: Randolph dope
« Reply #7 on: August 29, 2020, 01:10:10 PM »
So Dan, you just go to an auto paint supply  store and ask for what pigment exactly? Acrylic lacquer pigment? Most of the auto paint supply stores here no longer deal in Acrylic Lacquers. Not sure if that matters.
Re: Randolph dope
« Reply #8 on: August 29, 2020, 08:13:08 PM »
Jim,
You might try dropping Wind U a note and asking him how to match the paint, since he developed it. Windy has a YouTube channel if you search YouTube for Windy U it will come up and you can send a comment.
Best,   DennisT
« Last Edit: August 30, 2020, 06:19:39 AM by Dennis Toth »
Offline Tom McClain
  • Charter Member
Re: Randolph dope
« Reply #9 on: September 28, 2020, 06:44:08 AM »
Try Randolph Cadillac Red.  Pretty Close.
Tom McClain
Re: Randolph dope
« Reply #10 on: September 28, 2020, 08:01:46 PM »
 Brodak sells Miss Ashley Red, which is Randolph.
 https://brodak.com/pub/media/paint-chart.jpg
Re: Randolph dope
« Reply #11 on: October 04, 2020, 08:33:34 AM »
I dealt with Univair, the Randolph dealer in Colorado.   They mix the colors on site.  Unfortunately, I could not induce them to scan from my sample.  They just mix what's on the menu.  But they do have a higher-level parent company with a larger selection, which they will mix.
I was able to get Home Depot to scan samples and add pigment.  If you are willing to risk a few quarts of Randolph white, you might try getting HD to tint it for you.  I have done that with some success.  Worst case is a quart of dope in a slightly off color.
Re: Randolph dope
« Reply #12 on: October 04, 2020, 09:41:59 AM »
      This is a good idea, and may be able to be done more accurately if there is an auto paint store that can do the tinting and mixing for you. You can start off with clear, and be more sure of the mix.
