  • July 17, 2025, 08:32:41 AM
Author Topic: day 24 sanding  (Read 29661 times)
Offline RC Storick
day 24 sanding
« on: October 31, 2014, 10:27:47 PM »
« Last Edit: November 01, 2014, 11:10:41 PM by Robert Storick »
Re: day 22 sanding
« Reply #1 on: October 31, 2014, 11:05:49 PM »
 Coming right along, is that your usual NAPA primer?  Nice to see you found a way to do full wheel pants on it. I'm curious though, why the separate inner cover on them?
Offline RC Storick
Re: day 22 sanding
« Reply #2 on: October 31, 2014, 11:07:53 PM »
I fly on asphalt and the light wheels wear out in 1 season. So I made the pants so I can change wheels. Yes same DC540 primer
Re: day 22 sanding
« Reply #3 on: November 01, 2014, 12:37:29 PM »
 I see, good plan. ;D
Offline RC Storick
Re: day 22 sanding
« Reply #4 on: November 01, 2014, 08:51:36 PM »
Day 24 more sanding Video
« Last Edit: November 01, 2014, 09:33:47 PM by Robert Storick »
Re: day 24 sanding
« Reply #5 on: November 03, 2014, 06:19:27 PM »
 Another good video.
 I've never bothered with one of those foam sanding blocks but after watching here I like the idea, I think I'll give one a try next time around. y1
Offline RC Storick
Re: day 24 sanding
« Reply #6 on: November 03, 2014, 09:11:21 PM »
I am editing days 25 and 26 now. It will up uploaded to CLC later tonight.
Re: day 24 sanding
« Reply #7 on: November 03, 2014, 09:20:26 PM »
 I meant to ask earlier in this build how the perimeter sheeting around the wingtips is done, like on this model. I've seen this style of tip construction on occasion and it gives a nice clean overall look. I've always wondered how its done to get all the compound curves to come out right.
Re: day 24 sanding
« Reply #8 on: November 04, 2014, 04:21:17 AM »
Robert,
What size three blade prop are you using?
Size and pitch?
Tru Turn spinner cut for that prop?
Looks good!
Offline RC Storick
Re: day 24 sanding
« Reply #9 on: November 04, 2014, 07:17:58 PM »
Robert,
Size and pitch?
Looks good!
Prop is Master air screw 11x6 three blade. This is not the definite prop.
Spinner is Brodak 1 3/4  I cut it.
Re: day 24 sanding
« Reply #10 on: November 04, 2014, 11:11:17 PM »
Oy! 24 days of sanding sounds a bit much to me.  VD~ Steve
Offline RC Storick
Re: day 24 sanding
« Reply #11 on: November 05, 2014, 09:49:34 AM »
Day 27 is now uploading and there is over 14 hours of video on this model to date. Should be ready to paint at the end of today. Then more sanding. mw~
Offline RC Storick
Re: day 24 sanding
« Reply #12 on: November 05, 2014, 10:59:54 AM »
Day 27 is now ready to view here http://www.clcraftsman.com/dope-finish-day-one-continental/
It takes you through all the steps I took thus far.
You must be a paid subscriber to view these videos. Starting at the end of the month I will be doing a 1 hour a day class on designing and building your ideas from scratch. No plans just TLAR.
Re: day 24 sanding
« Reply #13 on: November 05, 2014, 09:02:05 PM »
No plans just TLAR.
 Yep, my favorite way to build, just good 'ol eyeball engineering. ;D
 How about some info on how you build and sheet this style of wingtip?
Offline RC Storick
Re: day 24 sanding
« Reply #14 on: November 05, 2014, 09:52:55 PM »
I show it all in Control line Craftsman
Offline RC Storick
Re: day 28 ready to spray
« Reply #15 on: November 05, 2014, 10:18:30 PM »
Here is the progress
Re: day 24 sanding
« Reply #16 on: November 06, 2014, 05:50:45 AM »
Robert,
Did I miss your "Wheel Pant" Video?
Do you have a Video on the construction of them?
I did see the video where you cut the openings in the wing.
Offline RC Storick
Re: day 24 sanding
« Reply #17 on: November 06, 2014, 06:47:48 AM »
Robert,
My job is to make the video's your job is to watch them. Yes there is a pants construction segment. It's even marked as such
Re: day 24 sanding
« Reply #18 on: November 06, 2014, 10:04:46 AM »
I found it! I found it!
Re: day 24 sanding
« Reply #19 on: November 06, 2014, 05:47:09 PM »
 Perfect answer. D>K
Re: day 24 sanding
« Reply #20 on: November 07, 2014, 07:20:39 AM »
Wayne,
All these years in modeling, it's hard to believe you've never seen this style of construction on a wingtip before, or that you've never done it?
I had wingtips like this on selected stunt models as far back as the early 60's. i.e. my twin boom Ares, both of them.
I've also used this style in builds back in 2011 with The New American, photos were posted.
Here's the Ares twin boom wing, brought to life  and The New American.
You should try this, it's easy and light.
I can't believe this is the first model that Robert has used this style of tip construction on either?
Is it Robert?
Offline RC Storick
Re: day 24 sanding
« Reply #21 on: November 07, 2014, 03:35:57 PM »
No been doing it sense the late 60ty's
