  • July 18, 2025, 01:39:38 AM
Author Topic: Cutting back base coats prior to trim  (Read 1073 times)
Online Curare
« on: February 03, 2013, 06:13:24 PM »
Hey guys, I'm getting close to finishing my electrified oriental, and I've hit a bit of a head-scratcher.
Normally I lay a base coat, cut that back with 800 wet, and then lay down my trim.
I'm wondering whether 800 is really the way to go, should I be using something different? 1000? Steel wool? Cheese?
Greg Kowalski
AUS 36694
Re: Cutting back base coats prior to trim
« Reply #1 on: February 03, 2013, 07:33:39 PM »
I use 0000 steel wool, myself. Be careful not to cut through the base color.
Online Curare
« Reply #2 on: February 03, 2013, 07:54:56 PM »
Do you find its enough to flat it out?
I've got a bit of orange peel which I'd like to flatten out.
Greg Kowalski
AUS 36694
« Reply #3 on: February 03, 2013, 08:05:37 PM »
It kinda depends on how much paint you have on. If there's enough, then it's worth hitting it with 800 for the high spots then use steel wool to flatten it out. But it kinda depends of the depth of the paint. It's really easy to go through then you have to re-shoot. If the orange peel isn't bad, then just use steel wool to get it in the neighborhood and shoot your trim them worry about getting it completely flat with the clearcoat.
Online Curare
« Reply #4 on: February 03, 2013, 09:56:37 PM »
Sounds like a plan.
This started out as a weekend hack, and somewhere between silkspanning and now I got carried away  b1
Greg Kowalski
AUS 36694
