  • July 20, 2025, 04:16:57 AM
Author Topic: Covering the fuselage before or after..  (Read 4055 times)
Offline Ty Marcucci
« on: May 02, 2012, 08:34:38 PM »
Question: How many of you cover the full type fuselage before adding the wing, using silk span or carbon veil?
On profiles, I cover it before installing the wing, the wing is always covered before I install it
It seems that I have making it harder for me to get a nice finish by fighting with the silk span, trying to put it on  just so  after the wing has been installed.
« Last Edit: March 09, 2020, 11:08:30 AM by Ty Marcucci »
Ty Marcucci
Re: Covering the fuselage before or after..
« Reply #1 on: May 02, 2012, 09:36:23 PM »
 I think it's all just personal preference. To me it kind of depends on the overall design layout of the particular model that your working with and how difficult it is, or isn't, to work around after it's fully assembled. Short coupled models can be a bugger to work on between the wing and stab if you've got it all assembled.
 Typically, on a full fuse model, I would do the fuselage silkspan work after the wing is in. On profiles I usually do the fuse before I put the wing in. On both types I do all of the tail surfaces before attaching them to the model.
 And no matter how tempted, always wait 'til the very last before doing fillet work. n1
« Reply #2 on: May 02, 2012, 10:11:02 PM »
never.   :)
« Reply #3 on: May 02, 2012, 10:22:47 PM »
Offline Mike Haverly
« Reply #4 on: May 02, 2012, 10:42:23 PM »
never.
Some of us, many actually, use other media such as carbon fiber veil.  I have used Polyspan as well.  Whatever floats your boat.
« Reply #5 on: May 03, 2012, 11:41:01 AM »
Sorry, thought that was clear, Wayne. I always cover after the airframe is complete. Probably my OCD taking over.
Offline Jim Thomerson
« Reply #6 on: May 03, 2012, 11:52:19 AM »
It depends.  I like to cover seprately.  It gruntles me to cover a fuselage with a single piece of silk.
« Reply #7 on: May 03, 2012, 09:11:39 PM »
 Even the wing afterwards?
 I've always covered my wings before installing them, and by 1/4's. Many many moons ago when I was a total newbie at all this stuff in Junior High School, someone told me that overlapping the wing covering a few inches at the center added significant strength at the center section. I started doing it that way then, and still practice the habit today. I don't totally buy the strength benefit anymore, but I guess it sure can't hurt.
« Reply #8 on: May 03, 2012, 09:23:53 PM »
Well, I've built some heavy planes, but I've never had a wing peel off. I've seen some others not so fortunate.
« Reply #9 on: May 03, 2012, 09:56:24 PM »
I build take apart models thesedays, so I only ever cover the wings without it installed.
Infact, I paint /clear and buff the wings without installing it to the fuse.
INFACT..... I also travel to the field with the wing not installed into the fuse..
However when I build 1 peicers I finish everything - completed airframe then start the finishing process with carbon Veil.
« Reply #10 on: May 03, 2012, 10:04:03 PM »
 Yeah, I'd say if anyone depends on the covering job to holds the airplane together the model would likely have plenty of other "built-in" issues as well. I just keep doing mine the way I always have out of habit, I don't believe I'm gaining anything by the center overlap, that's why we put spars in 'em. ;D
Offline Gene O'Keefe
« Reply #11 on: May 04, 2012, 02:42:16 AM »
I cover mine separately.
Gene O'Keefe
AMA 28386
« Reply #12 on: May 04, 2012, 09:53:28 AM »
PJ,
That's what happens when you use a go cart to take your plane to the field.   ;D
My next plane will be a take apart. I've developed my own system.
Offline Allan Perret
  • Proverbs
« Reply #13 on: May 04, 2012, 05:45:49 PM »
On Profiles I have always covered the wing and fuse seperately and then assemble.
For the first time on a full fuse I did it on most recent build of the Olympic.
It worked out well and plan to do it like that will all future builds.
For me the advantage is its easier to do the fuse in fewer pieces.
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #14 on: May 04, 2012, 07:20:54 PM »
Randy : "I've developed my own system"
Yes you have.......
Your going to finish it, then pull it out of the model and re-do it becasue its too heavy?
 S?P
« Reply #15 on: May 04, 2012, 07:22:16 PM »
Nope. I'm working on the wing system now.
Offline John Sunderland
« Reply #16 on: May 04, 2012, 09:05:57 PM »
I cover the fuse last because it is easier to jig up the wing and stab for accuracy with the top and bottom blocks off of the fuse.
« Reply #17 on: May 06, 2012, 05:09:53 PM »
Juz kiddn Randy :-)
I look forward to your work.
« Reply #18 on: May 11, 2012, 05:51:21 PM »
Hi Ty,
I have done it both ways and now tend to cover the model once it is in one piece.  Don't know why, just my comfortable way of doing it.
On one large model I had been watching some of Windy's videos so I finished all the sub assembles up to where they had been primed and sanded.  Had more hanger rash once I assembled everything so I haven't done it since. LL~ LL~
BIG Bear
RNMM/AMM
