  • August 04, 2025, 05:29:26 AM
Author Topic: low cost silkspan?  (Read 1810 times)
Offline Ken Burdick
low cost silkspan?
« on: April 15, 2017, 07:26:46 AM »
I try various techniques to finish vintage combat wings for Combat Graffiti. Once I bought some "dress lining" from a local fabric store here, but never go around to trying it as it seemed thick to me. I have a voodoo that got smacked by a buddy and it used to be covered with super monokote. When I finally got all of that stuff off and the wing prepped, I tried the lining on it. I was sceptical even after I had it all doped on. I used glue to hold it to the wingtips along with pins and applied it dry in a single wrap on the inboard and outboard sides instead of 4 panels. I then shrank it with water to take out any small wrinkles. After the first coat of nitrate, I was sure this was a mistake, it looked like a fuzzy slipper. I sanded the wing with light sandpaper and it smoothed out. I had a pooch at the tips where I had slit the covering and overlapped the covering right at the start of the wingtip. It sanded out nicely so I put another coat on and sanded that. By the end of the 3rd coat it was looking pretty nice, like old days silkspan, so I shot it with buyterate and the look was very nice and not fragile like silkspan at all.
This was a "medium" thickness material, as I thought the thin was too weak by pulling it until it began to separate. I bought 6 ft for 2.50 or so. I'm currently building a James Mears "Raunchy" and will cover it with the same.
K
Re: low cost silkspan?
« Reply #1 on: April 15, 2017, 11:42:51 AM »
Is this the poly-ester material?  I've used that several times with good results.   I know the first coats of dope it didn't look good but then the 4th or 5th coat and what a difference.  I use butyrate from start to finish.   But my latest finish I'm now using, no dope involved.   Waiting for chance to fly the planes.
Offline Ken Burdick
« Reply #2 on: April 15, 2017, 02:30:29 PM »
I think it's the polyester stuff.....believing that, I attempted to heat shrink it and fired up the heat gun. Big-o mistake-o........it seemed to be going ok and while not shrinking like I had hoped, I thought it was getting tighter when one spot burst into flames! It was a smallish dot and I was lucky to get it out in time before it really lit up. What is the material you are using, how heavy is it? Light medium or heavy.
« Reply #3 on: April 15, 2017, 08:59:29 PM »
I use the jacket lining poly-ester that has many colors to choose from.   I put it on using a heat sensitive glue.  Put it on as tight as you can.  Yes the material will shrink a little but goes slack again when it cools.  It is the butyrate dope that really makes it shrink tight.  I have tried the iron after a couple of coats of dope, but it will some times goes slack until more dope is applied.  If you do a search you will see where I'm using mylar or SLC over the poly-ester and seems to work okay.  I use Mod Podge to put the poly-ester or the new TITI wanna be silk span on.    Smear/brush it around the edges for the material.   Sand excess off like silk span.   O the TITI material do one panel at a time.  Put down the TITI and then the mylar and then do the other panel.  Remember to bottom of wing first then when you do the top over lap the mylar about 1/2 inch.   If you don't you will discover why when your fingers or thumb goes thru the TITI before its covered.   Also don't put the TITI on wet as it makes one big mess.  Don't ask how I know.
« Reply #4 on: April 15, 2017, 09:07:16 PM »
By the way the combat wing I used Poly-span under the mylar.
