Building Tips and technical articles. => Paint and finishing => Topic started by: kevin king on October 27, 2023, 09:13:29 PM
Title: compatible pigment for dope
Post by: kevin king on October 27, 2023, 09:13:29 PM
 S?P
https://www.epscca.com/en_GB/products/colorants/opticolor-xp-4100/
Title: Re: compatible pigment for dope
Post by: James H. Dean on October 27, 2023, 09:32:23 PM
I have found that most solvent automotive paint systems toners will work with dope.
Post by: Dan McEntee on October 28, 2023, 07:38:03 PM
  Back when I was flying free flight a lot, I got a copy of the book of WW-2 rubber powered model  plans that Model Builder put out back in the early 80's. In there was an article on buying Floqui railroad paints in colors that match WW-II military colors. Floquil paints back then were lacquer, and if left to sit the pigment would settle pretty quickly. The carrier could be poured off and then the pigment could be added to clear dope. That worked well, but was able to add it to a clear acrylic paint that I could spray on those foam rubber scale model from Bentom, and it didn't bother the foam. I'm not an expert, but I would think pigment would be sort of inert until it is added to type of clear that you want to use it on. I never got any more experience with than what i described.
