  • July 20, 2025, 06:39:40 AM
Author Topic: Clear topcoat in spray can  (Read 4254 times)
Offline Mike Griffin
« on: May 31, 2017, 06:28:16 AM »
Since I do not have any spray equipment, I am looking for a good clear coat in a spray can to go over auto lacquer color finish.  Does anyone know of a good brand of this?
Thank you
Re: Clear topcoat in spray can
« Reply #1 on: May 31, 2017, 07:29:52 AM »
Thank you
2K Spray Max aerosol can.
It's been talked to death on the Forum in plenty of places.
The price has been reduced by some suppliers, I've seen the high gloss on ebay for as low as 13.00 and change a short time back.
CB
« Reply #2 on: May 31, 2017, 01:36:10 PM »
CB
Thank you Charles.  I guess I missed that discussion somehow...
« Reply #3 on: May 31, 2017, 06:31:59 PM »
Mike,
I apologize if my mentioning that this product has been talked to death seems a bit sharp.
Nothing was intended other than it's been talked to death. So forgive me.
I only use the product outside with a quality 3M mask.
Has a nice wide spray and goes on great.
Someone in the Forum introduced it to me, I can never remember who? Forgive me again.
I tried it and have now used it on all my models.
It has other uses also, like redoing fogged headlight covers. I just did mine on my Tuscon.
I also just purchased a can of semi-gloss for the Stuka Tank Buster. The semi-gloss or semi-matt is pricy.
If you use it, let me know.
CB
Online Carl Cisneros
« Reply #4 on: May 31, 2017, 09:58:49 PM »
Charles
that would be me.   H^^
Carl
Carl R Cisneros, Dist IV
Control Line RB
« Reply #5 on: June 01, 2017, 05:30:24 AM »
Charles
Carl
Carl,
Yes, you are correct!
Carl, I cannot thank you enough for that information.
I've said this many times, I started using auto 2 part clears as far back as the early 80's on all my R/C pattern Ships, customers models also.
I shot all paint and clears through professional spray equipment. I no longer have access to this kind of equipment and have absolutely no interest in purchasing any of this equipment.
So, with the use of simple aerosol cans for some colors and the air brush for other colors, I get the job done.
I get the job done using absolutely no color dope either.  ;D
Sure, there's plenty of advantages using a paint you can mix and applying it with professional equipment, but for an old washed out hack like me, I'll stay with the simple process I'm using and "Carl's 2K Clear."
I even paint my models outside.
Works for me!
Thank you Carl.  H^^
Here's the ARGO, International, 007 Spectre.
All aerosol cans and "Carl's 2K Clear!"
CB
Offline Chancey Chorney
« Reply #6 on: June 01, 2017, 05:03:32 PM »
I have used rattle can Minwax clear before and worked very well, and is also fuel proof. Black can, and does not yellow. I have it over mine and the white is as white as the day I applied it.
« Reply #7 on: June 01, 2017, 08:32:14 PM »
Thanks much Charles.
I have been using that 2k clear now for about 6 yrs if not longer.
It does go on nicely, dries crystal clear and is good and fuel proof to at least 65% nitro. ( I know, I run boats using 65% fuel and it laughs at the fuel)
Carl
Control Line RB
« Reply #8 on: April 02, 2018, 04:00:32 PM »
Sorry for replying to the old post but I need to know it the MinWax Black Can you used was the Lacquer.  I need something to seal the ink lines over monocoat.  I tried the Balck Can Lacquer and it worked perfectly but was not even close to fuel proof after 4 days.  Is this the wrong stuff or do I need to let it dry more?  Thanks
« Reply #9 on: April 21, 2018, 10:13:26 PM »
Offline 944_Jim
« Reply #10 on: April 26, 2018, 09:42:55 PM »
Mr. Chancey, do you use this on your 1/2A models? It doesn't  go on the little guys too heavy?
If this is true, you may have just changed my finishing methods!
Thanks in advance,
