  • July 17, 2025, 08:47:55 AM
Author Topic: Clear spray can & fuel test results  (Read 2220 times)
Offline Terry Caron
« on: November 24, 2015, 02:01:25 PM »
F everyone's I, after 2 days cure time over homemade inkjet decals, a heavy coat of either Miracal Premium clear enamel (Co-op) or Plaid Patricia Nimocks Clear Acrylic Sealer (craft store) are proof against 15% nitro for at least 10 minutes.
Be sure there are no pinholes in the clear coat.
Seems they ought to be okay if Windexed after each flight.
May be extreme, but after 2 weeks cure, both sprays exhibited severe wrinkling following a fresh drop of raw fuel every 10 mins for ~40 mins.
Terry
NACA member, Huntsville, AL
AMA 249824
NRA Life Member
Re: Clear spray can & fuel test results
« Reply #1 on: November 25, 2015, 08:41:42 AM »
Terry,
I've been using the 2K Spray Max. On four model so far.
And will use that product on my next model also.
I've had great results with the 2K Spray Max clear.
Charles
Offline Ken Burdick
« Reply #2 on: November 25, 2015, 09:55:01 AM »
where do you get 2k? What is the full name and Mfg?
Thanks.
Offline Terry Caron
« Reply #3 on: November 25, 2015, 10:46:57 AM »
It's USC 3680061 2K GLAMOUR HIGH GLOSS CLEAR - I found it on eBay for ~$22 incl shipping.
Reports indicate it may be the best on the market for fuel-proofing but, with a "shelf life" of only 48 hours after activation, I'm waiting for a major clearcoating operation before I try it.
The sprays noted above are cheap, easily obtainable and I'm only "spot coating" over small decals.
Terry
AMA 249824
NRA Life Member
