Building Tips and technical articles. => Paint and finishing => Topic started by: Tim Wescott on April 20, 2019, 03:46:56 PM
I got a plane from a friend (not the Atlantis, which I know to be clear-coated). It had some serious hanger rash, which required patching some ripped silkspan.
I want to spot in clear over the repairs, but I don't know if the plane has been waxed.
Is there a good reliable way of removing wax from dope that doesn't remove the dope, too?
Prep sol then windex.
Naptha, works great and much less expensive than Prepsol.
Ammonia strips wax. Floor wax, automotive wax, crayon and candle wax, doesn't matter too much. Silicone based coatings are another story, and I don't know how to remove those.
A gallon of grocery store ammonia is some $2. Dillute in warm water, apply, let sit a few minutes, wipe off. When satisfied rinse with water. Allowing overnight to dry is probably a good idea too. I would use several clean rags for each step and not too wet.
I would still test but I am pretty confident that dope is unaffected by ammonia.
Phil
If you use Ammonia make sure have plenty of fresh air. D>K
