  • June 15, 2025, 07:20:38 PM
Author Topic: 2K Max Compatibility  (Read 5613 times)
Offline David_Ruff
  • David Ruff
  • Retired Army
« on: December 25, 2023, 07:52:29 AM »
Wondering if 2K Max would cause a problem with Ultracote polyester iron on.
Planning to mask off anything with the Ultracote.
I am planning to use 2K over Krylon on the fuselage of the Skyray 35.
I will use wood lacquer on the balsa fuselage, then Krylon.
Also I use glass resin on the engine mount area to insure it is fuel proof.
Just glad to be here
Offline Larry Wong
Re: 2K Max Compatibility
« Reply #1 on: December 27, 2023, 09:33:40 AM »
I have done it and it’s not a problem just scuffing the ultra cote with scotch pad
Larry
