  • July 20, 2025, 02:53:54 AM
Author Topic: Clear coat prep  (Read 1674 times)
Offline david beazley
Clear coat prep
« on: January 12, 2013, 09:20:55 AM »
I'm getting real close to shooting clear on my Brodak P-51. It has silver Rand-O-Fil over silkspan, top coat Randolph Cadillac Red vinyl graphics.  Question is what to use for a wipe down prior to shooting the clear?  Is naphtha OK to use on butyrate to remove fingerprints, etc, or what do the experts use? ???
AMA # 2817
Offline Dan Bregar
  • Field Marshall
Re: Clear coat prep
« Reply #1 on: January 12, 2013, 09:38:44 AM »
I'm not one of the "Experts", but Windex works well for me.  :)
AMA 33676
Re: Clear coat prep
« Reply #2 on: January 12, 2013, 09:47:39 AM »
I would use an automotive grade cleaner that's designed for the last thing you would wipe the surface down with before applying the clear coat.
Surgical gloves should be worn from this point on.
Also, you could scuff your vinyl down with a fine pad lightly. I believe the fine pads are gray?
When I provide graphics for customers, that I know are going to clear them, if they allow it, I scuff the material up before cutting. The clear coat covers the scratches, but allows for the clear to adhear better. Just like clearing a canopy that has been fine sanded.
I never mix brands. Unfortunately, with an auto primer over dope, I'll have no choice. But I'm comfortable with that.
Hope this healps.
Charles
Re: Clear coat prep
« Reply #3 on: January 12, 2013, 12:19:36 PM »
Original formula Windex is the official prep cleaner of the Jive Combat Team.  Be careful not to leave blue residue from sneaky drips that run around to the other side of the wing.  I also use PPG DX 330 Acryli-Clean.  It's automotive stuff like Charles mentioned.  I had a problem with nitrile gloves leaving a residue that messed up the Isocyanate Death Paint.  People here told me to get my gloves at the car paint store, which I did the next time.
H. Rush
Through-hole man trapped in a surface mount world.
Re: Clear coat prep
« Reply #4 on: January 12, 2013, 01:49:38 PM »
Just be careful. Some products like naphtha can take the paint right off. This is particularly true if you are using urethane colors. I've also run into problems with auto toners mixed with Randolph's clear. Stuff like AcryliClean can take the paint off. I've used denatured alcohol, Windex, soap and water and each has it's advantages and drawbacks. Suggest you test any product before putting it on the plane.
Offline Mike Haverly
Re: Clear coat prep
« Reply #5 on: January 12, 2013, 06:20:33 PM »
I use plain old naphtha.  It doesn't leave residue and I (so far) haven't had any issues with it attacking any paint, including some water base urethane, Auto Air Colors.  Alcohol and Wyndex will attack water base products.  Like Randy said, testing is really important.  Also, make sure you grab the right bottle of "whatever" before you smear it on your wing!  I accidentally grabbed some acetone once, didn't cause much trouble though, unlike a certain Impact pilot ;)
Re: Clear coat prep
« Reply #6 on: January 13, 2013, 07:07:14 PM »
Don't be mean, Mike. All of us have done dumb stuff. Even a certain Bellevue Bomber.
John Leidle
Re: Clear coat prep
« Reply #7 on: January 14, 2013, 09:15:09 PM »
 Inhaleing that Naptha is pretty nasty I hear some folks say. Actully worse than some other stuff,,,, keep fresh air moving through.
