  • July 20, 2025, 03:48:40 PM
Author Topic: Clear butyratedope  (Read 1504 times)
Offline Larry Wong
Clear butyratedope
« on: November 18, 2020, 05:22:24 PM »
What cause the clear to turn white when raw 10% is drip on the plane ? I’ve bee on the dark side to long! Is it the wax ?
Larry
Re: Clear butyratedope
« Reply #1 on: November 18, 2020, 06:19:43 PM »
   The clear is just not fuel proof enough, not even fuel resistant. Common thing these days and a million line shave been written about this in the forums.  Most guys these days put at least a light coat of two part automotive clear on at least the nose and fuselage around the wing leading edge. Some do the whole model. You mentioned wax and you may want to try some good wax on the nose area  as a couple of coats of wax may help if you don't want to try the 2 part stuff.
Offline Larry Wong
« Reply #2 on: November 18, 2020, 06:29:18 PM »
Thanks that what I though I just applied a coat of 2k on the cowl today. y1
Larry
