  • July 31, 2025, 05:43:08 AM
Author Topic: SIG Miami Blue  (Read 8754 times)
Offline Steve Dwyer
SIG Miami Blue
« on: February 20, 2024, 02:53:02 PM »
I have an unopened gallon of Sig Miami Blue Supercoat I snagged years back at a swap meet.  Different sources are showing the thinner is still available. If not can I use Randolph Butyrate or Nitrate thinner with Sigs's Supercoat? Any experience?
Re: SIG Miami Blue
« Reply #1 on: February 20, 2024, 03:59:54 PM »
   All of SIG's color dope was blended with their Litecoat dope, which is a plasticized, low shrink butyrate dope.i think all of their dope was repackaged Randolph's, so I think their butyrate dope will work fine. Do a search on the main and finishing forums and I think you will find more confirmation.
Offline Steve Dwyer
Re: SIG Miami Blue
« Reply #2 on: February 20, 2024, 05:04:28 PM »
Thanks Dan, I began a search but found a gazillion Sig Paint entries and gave up. I'll take another look; I do have a ton of Randolph finishing material on hand, so it'd be good if they are compatible.
Offline Jim Svitko
Re: SIG Miami Blue
« Reply #3 on: February 26, 2024, 05:10:17 PM »
Sig dope has a different smell than Brodak dope or Randolph dope.  Does this mean that the components are not compatible with each other?  I can't say for sure.  All I know is that I have used Randolph butyrate thinner with Brodak butyrate dope.  And, Brodak butyrate thinner with Randolph butyrate dope.  No problems.  I would not try to use nitrate thinner with butyrate dope.  I have never done that, but something tells me it would not turn out very well.
Pour out a little bit of that Sig Miami blue into a small jar and add some Randolph butyrate thinner.  Spray or brush it on a test piece.  See if there is any adverse reaction.  Better to test it yourself this way rather than ruin an entire paint job.
Offline Ty Marcucci
Re: SIG Miami Blue
« Reply #4 on: February 29, 2024, 09:00:01 AM »
I use Randolph's thinner on all my butyrate dopes including SIG Lite coat clear with NO problems what so ever and have been doing so since 1999.  H^^
Ty Marcucci
