  • July 19, 2025, 09:33:34 PM
Author Topic: Butyrate primer vs sanding sealer?  (Read 2587 times)
Offline david beazley
« on: March 19, 2016, 03:38:54 PM »
Does anyone know the difference between Brodak primer and sanding sealer?  Seems to me that they both have a lot of solids (talc?).  Is primer just white dope with talc or zinc stearate added like sanding sealer is clear dope with talc added?  I bought a can of primer to try under lighter colors like yellow so it covers with fewer coats.  Do you need both or can primer be used as sealer too?
AMA # 2817
Re: Butyrate primer vs sanding sealer?
« Reply #1 on: March 19, 2016, 06:32:13 PM »
David,
Even though I don't like using it, I use just simple butrate clear dope to apply silk or silkspan over all the wood or bays, and the same clear to seal the wood after with a few coats depending on how you thin it.
I'm now using a white primer over the sanded clear with great success, but removing as much primer as possible before applying paint.
The white primer is really opeque.
Charles
