  • August 04, 2025, 02:23:07 AM
Author Topic: Recovering my 45 year old Shark 15 questions.  (Read 1178 times)
Offline frank mccune
« on: March 21, 2014, 01:20:06 PM »
     Hi All:
     I got my 45 year old Shark 15 out of the attic and I saw that the Monocote had pulled loose from the trailing edges on two wing panels. How may I repair this model?
     One thought is to slather Balsarite all over the edge of the wings where the Monocoat has pulld away and attempte to iron it back down.  I would then heat shrink it with a heat gun.  Sounds easy but will this old Monocote still have any shrink left in it.  I doubt it as it becomes vey hot in the attic.
    Perhaps I should remove all of the old Monocote and apply new Monocote.
    Or I could use some of the old silk that I have in the attic and do a silk and dope job.  Does silk "rot" when it becomes old even it has not removed from the pacage.  This is some that I bought from World Engines circa 1975! LOL
    Any thought about what to do with this great airplane?
        Stay well,
        Frank
Offline Gerald Arana
Re: Recovering my 45 year old Shark 15 questions.
« Reply #1 on: March 21, 2014, 02:52:15 PM »
If I were you............. I'd remove all the old (and probably brittle) money coat. Then I'd cover it with polyspan and SLC.
There are some articles covering this method on this forum. Check'em out!
Jerry
Offline 55chevr
« Reply #2 on: March 21, 2014, 05:32:46 PM »
I would just recover with Monokote.
Joe Daly
« Reply #3 on: March 21, 2014, 06:30:31 PM »
I think new monokote would be fine, as long as there's no oil soaked wood under the old. There have been some posts about removal of oil that's soaked in...using "search" should turn them up. Something like a paste of corn starch and naptha (?) should be close...slather it on, work it into the grain, let it dry completely and vac it off, then repeat until it's gone. Some folks use "K2R", a household stain removal product in a spraycan.  H^^ Steve
« Reply #4 on: March 26, 2014, 02:03:46 PM »
Silk is a real crapshoot!  I still have a model built in 1963 covered in Esaki silk and it's still like new.  Other planes, the silk rotted away after 3-4 years.  Still don't know why.
« Reply #5 on: March 26, 2014, 10:08:33 PM »
 45 year old model? No offense, but I'd hang the crusty old one on the wall as inspiration and build a new one.  y1
« Last Edit: March 27, 2014, 08:30:14 PM by wwwarbird »
« Reply #6 on: March 27, 2014, 08:47:47 AM »
That would be a good choice in my opinion too.  I tried to recover my first Thunderbird.  Had upright engine.  At that time I did not fly the pattern.  Just loops, eights and inverted flights.  Well, to make a long story short.  The wood in the plane was old and brittle from hanging in the basement.  Also the Testors Glue had let loose in most of the joints.  Like an idiot I finished off the destruction of the plane and it went in the trash.  To me the Thunderbird was the most beautiful of the planes in that period of time.
