  • August 05, 2025, 02:05:44 AM
Author Topic: Silk  (Read 1445 times)
Offline Wade Bognuda
Silk
« on: December 23, 2011, 03:55:32 PM »
I just used Rit dye on the silk I am going to use on a Ringmaster and the result is excellent!! I pretty much followed the directions on the package and it looks real good.  ;D ;D
Re: Silk
« Reply #1 on: December 24, 2011, 07:48:49 AM »
When applying silk to solid sheet surfaces, should it be applied dry or wet?
Re: Silk
« Reply #2 on: December 24, 2011, 08:25:14 AM »
In my experience, apply it wet.   Make sure you have a good base coat to adhere to. H^^
Offline Gene O'Keefe
Re: Silk
« Reply #3 on: January 07, 2012, 08:52:08 AM »
Definitely wet and be sure that the grain runs wingtip to wingtip.....
I know it's your plane, but why put silk on the solid sheet surfaces (I'm assuming tail section) ?
it adds unnecessary weight...better of to use medium silkspan and it won't take as much to fill the weave. JMHO
Gene O'Keefe
AMA 28386
Offline Jim Thomerson
Re: Silk
« Reply #4 on: January 07, 2012, 10:58:13 AM »
There may be a new and better silk available in the future.  Science marches on!
http://www.sciencedaily.com/releases/2012/01/120106113037.htm
Re: Silk
« Reply #5 on: January 08, 2012, 09:27:06 AM »
How do you tell which way the grain is? I like the esthetics on solid sheet surfaces.
Re: Silk
« Reply #6 on: January 09, 2012, 08:21:47 AM »
Hold it up to the light,and you should be able to see the grain.
Re: Silk
« Reply #7 on: January 11, 2012, 06:41:25 PM »
Which way do you apply it? Thx.
larry borden
Re: Silk
« Reply #8 on: January 11, 2012, 08:34:09 PM »
Grain running span wise. I lay the silk over the wing dry and then spray a light coat of water to help hold in place. I then pull it tight and get the wrinkles out while applying dope around the edges. Once I get it as tight as I can, I spray a heavier coating of water over the wing and then let dry.
