  • June 16, 2025, 05:43:31 AM
Author Topic: Stripping heat shrink covering cleanup?  (Read 811 times)
Offline Steve Riebe
« on: March 10, 2013, 05:00:28 PM »
I'm stripping a Brodak Cardinal ARF, and the covering has left a lot of color in the balsa wood. Is there a solvent that might remove this? I appreciate any help you could give me.  I'm recovering it following some misc. crash repairs
Re: Stripping heat shrink covering cleanup?
« Reply #1 on: March 10, 2013, 05:07:15 PM »
Steve,
Bleach removes color. Other than that, I mhave no idea.
Charles
Offline Paul Wood
« Reply #2 on: March 10, 2013, 05:28:38 PM »
Steve,
I have found that Xylene works pretty well.  But, I've only used it to remove color stains caused by Monocoat covering.  Also try heating the stains with your heat gun to soften the glue.
Offline Steve Riebe
« Reply #3 on: March 10, 2013, 07:45:12 PM »
Paul, thanks for your help. I was able to get most of it of with xylene, at least to the point where I can think about a light sanding
