  • June 15, 2025, 03:23:34 AM
Author Topic: Leadouts contamination.  (Read 1191 times)
Offline Perry Rose
« on: December 09, 2021, 06:23:52 AM »
On a plane that was all paint and clear coat there was a catch in the controls. A bump. I finally found it being paint buildup on one of the cables. The two part clear really made it hard to remove but a razor blade did the trick.
Re: Leadouts contamination.
« Reply #1 on: December 09, 2021, 08:32:19 AM »
I mask mine off.
The inboard wing in that area really doesn't need a build-up of paint. Other areas? You decide.
CB
