  • July 20, 2025, 03:43:22 PM
Author Topic: Brodak Checkerboard  (Read 2599 times)
Online Mike Morrow
Brodak Checkerboard
« on: April 26, 2022, 03:49:52 PM »
Hello,
I purchased some red and white checkerboard from Brodak for a Ringmaster. I've used Windex before to put vinyl graphics on flat surfaces, but this is a little different. Before I go and mess it up how do I get it to settle over the wing ribs at the leading edge?
Offline Craig Beswick
Re: Brodak Checkerboard
« Reply #1 on: April 26, 2022, 03:53:57 PM »
Soapy water.
Whatever dishwashing liquid you have mixed with water.
It should give you enough slip to position it how you want then squeegee out or use a cloth to squeeze out the excess.
Craig
AUS 87123
"The Ninja"
« Reply #2 on: April 27, 2022, 05:36:03 PM »
I had the same problem with the rather stiff trim sheets, I wound up painting it on.
Best,    DennisT
Online Mike Morrow
« Reply #3 on: April 28, 2022, 05:34:47 AM »
Thanks. Didn't know if there was an easy way to make it flexible enough to go over all those compound curves.
Sent from my moto g(6) using Tapatalk
« Reply #4 on: April 28, 2022, 09:03:36 AM »
  The adhesive is pretty aggressive on these sheets, so make sure everything is clean, dry and not greasy in any way. As you apply the trim sheets, and you need to go around the leading edge, just try a slight amount of warm air, like from a hair dryer, not a heat gun, and see if that softens it up. Once you have it stuck down, run just the tiniest bit of thin C/A along the edges to seal them down and secure them.
   Dan Mcentee
Online Mike Morrow
« Reply #5 on: April 28, 2022, 09:41:13 AM »
Thanks. I'll try it the hair dryer thing and let you know how it goes.
« Reply #6 on: April 28, 2022, 11:31:24 AM »
Mike,
You may want to do a test piece before committing to the actual wing. This would also give you a chance to get a feel for how much heat to apply.
Best,   DennisT
Online Mike Morrow
« Reply #7 on: May 02, 2022, 07:16:10 AM »
Thanks for your help. Put the Ringmaster sticker on first successfully with Windex. Then did the checkerboard with Windex and a hairdryer. Sticker settled in over the ribs and leading edge. Worked like a champ.
« Reply #8 on: May 07, 2022, 08:08:03 PM »
I tried checkerboard, but I always get a wrinkle in it.
