  • June 15, 2025, 02:53:36 AM
Author Topic: Mod-Podge question  (Read 1725 times)
Offline Mike Griffin
Mod-Podge question
« on: May 31, 2021, 12:04:08 PM »
Do you need to thin ModPodge when laying down the Polyspan tissue or just use right out of the bottle?
Thank you
Re: Mod-Podge question
« Reply #1 on: May 31, 2021, 03:50:21 PM »
Thank you Ty.
« Reply #2 on: May 31, 2021, 08:35:50 PM »
So far I have used two types of Mod-Podge and have not thinned either one.   Use what Harbor Freight calls a bristle brush.   Brush the Mod -Podge straight from the jar.   Let dry and then put the covering on(doc paper, silk span and poly-span).  Then throw the brush away as they are cheap. D>K
Remember to not seal the material over open areas before putting top covering down. H^^
« Reply #3 on: June 02, 2021, 09:00:43 AM »
Thank you Doc.
