  • June 16, 2025, 10:41:49 PM
Author Topic: drying time before masking?  (Read 1098 times)
Offline Alan Buck
« on: March 01, 2011, 11:09:39 AM »
How long should you wait before you start masking a plane painted with dope? will be using 3m blue and green tape for masking. plane will have 4 colors on it.  Thanks
ALAN E BUCK
Online wwwarbird
Re: drying time before masking?
« Reply #1 on: March 01, 2011, 07:24:03 PM »
 It can depend on a lot of things from prep to temp, to how heavy is the base coat and how was it mixed, to who knows, pure luck even.
 I usually wait at least 24 hours, usually 48. Longer is even better, patience can be key.
 (Watch out with the 3M green, I don't know what you have but the bright green 3M that I have I would never use for paint work, way too sticky.)
« Reply #2 on: March 03, 2011, 01:29:52 AM »
Hi Alan,
For dope, I like to wait until I can't "smell" it.  After the base coat has quit "smelling", the trim colors are not quite as critical, it seems, unless you are going to be taping directly back over them.  I agree with Wayne, the "really green" tape (3/4"-1") from 3M has pulled up more paint that any other type I have used.  For that I like the orange spool "Blue tape".  It isn't wrinkled like regular "masking tape" and is low tack.  Has a "slick" texture.
The transparent green 1/8th" tape, or the blue vinyl 1/8th" tape (more flexible) is my preference for thin lines.  I have used some special tape made by a "pin striping" company that is the bomb!  I think it is from "Finesse it" or something like that.  Gotta get some more!
Big Bear
« Reply #3 on: March 03, 2011, 05:37:04 PM »
I use 3M blue painter's tape (low tack) and both 3M vinyl tape and Finesse Pinstripping's Edge tape for doing the edges. I usually wait about 24 hours before doing the next trim color.
« Reply #4 on: March 03, 2011, 06:21:29 PM »
Im starting to dislike you Randy  ;D
Now for MY answer..
I use 3M blue painter's tape (low tack) and both 3M vinyl tape and special 1mm cut tape for doing the edges. I usually wait about 24 hours before doing the next trim color. - Maybe 26 hrs ! HAHA Patience IS the key - you can touch it, colour sand it, but you may not be able to apply tape without it pull off...
Ive been impatient before - not thesedays..
